measuring throughput on S130 V2
Hello, I'm using the SDK 11.0.0 and S130 on both sides, and the projects ble_app_uart_c and ble_app_uart to connect a central and a peripheral through BLE. I was doing some measures to see how much data I could send defining different minimum and maximum intervals.
I got a throughput of 160kbps when using 7.5ms in the maximum and minimum connection intervals. But I don't think this number should be correct (not complaining because the more data I could send better). Just wanted to know if this is a normal number or maybe I'm measuring the throughput wrongly. I count the number of packets sent during one second and during 2 seconds and then calculated the throughput.
this is my code:
uint32_t timer2_number = 2000;		//timer in ms
			while(timer2_number != 0)
			ble_nus_string_send(&m_nus, sender, 11);
            timer2_number--;
			counter_t++;
            nrf_delay_us(999);
			ble_nus_string_send(&m_nus, end_packet, 16);
			printf("%f\n",counter_t);
			nrf_delay_ms(10000);
the max should be 7packets20B8*(1/7.5ms)=149.33kbps. And I'm getting 160kbps. can I use delays to measure this, or should I use timers to be more precise?
  • You are calling ble_nus_string_send() 1000 times in a second. And you assume that you send 20 bytes each time. 20 * 8 *1000 = 160 kbps. Calling ble_nus_string_send() doesn't mean that the packet is actually sent. You need to check the returned error code. I believe most of your calls return NRF_SUCCESS (0x00000000), but some return BLE_ERROR_NO_TX_PACKETS (0x00003004). I would remove the delay and count the number of calls of ble_nus_string_send() that actually returns NRF_SUCCESS.
  • I'm already counting the number of packets that I receive in the central part and those are the ones considered. I try to send every ms a packet to the central but with different times I get different number of packets. I receive 1000 packets in one second, with 7.5 for min and max interval connection, but I think this is not a real number, because it shouldn't let me receive all the packets I send in one second.
    EDIT I measured only the when I get NRF_SUCCESS and still got a throughput of 153.27kbps. I think is still a misleading number, but I'll work with it and be cautious!
  • I receive 991 packets (average) on the peripheral but only get 223 NRF_SUCCESS (average) on the central from the ble_nus_c_string_send. Can't understand the differences in this two numbers. Shouldn't they be the same? I'm only sending 223 packets successfully but receive 991? If anyone can help me understanding this I would appreciate. EDIT: Discover what I was doing wrong
  • I changed from delays to the use of timers to be sure of the time sampling. Now it seems more precise numbers, because I get 386 packets per second on the central and peripheral. Which give me a throughput of 62kbps for each side and 124kbps for both sides (fullduplex) wich is less then the 128kbps expected! Now the numbers feel more real
  • Hi Jorge,
    did u have a conclusion on the throughput thing, which I am very interested to know? recently I did some experiment, in which I could achieve 150kbps: 150 bytes of packets, sending rate is 1pkt/8ms. If I increase sending rate to 1pkt/4ms, I have a lot of lost packets, which I haven't really counted. 150kbps is quite similar to what you achieved. So I want to know you got any further work or results.
