ble_app_gzll & freeRTOS & peer manager
Hi
I am running some thing similar to the multiprotocol ble_app_gzll example but using freeRTOS and peer manager. Effectively the the main in ble_app_gzll example is a freeRTOS task.
  1. The first issue I came across was reinitialising ble. (ie this is the second time the ble is started) The conn_params_init()->ble_conn_params_init() failed with the error NRF_ERROR_INVALID_STATE It looks like the timer cannot be reinitialized.
Do I have to some how delete the timer when stopping the ble task. This would mean it would behave differently to the non freeRTOS version.
I have commented out the APP_CHECK error so it continues to run. I am assuming this timer never gets destroyed which is why the osHandle is not NULL
I can now stop and start the ble module. Is there a better way of doing this?
  1. However on the 3rd time of initialising there is now a problem with the peer manager. It fails in pm_init -> gcm_init() All the flags are BLE_CONN_STATE_USER_FLAG_INVALID
Any suggestions?
  • FreeRTOS and app_timer.c both uses RTC1. Can you use app_timer_freertos.c instead of app_timer.c? The first one uses RTOS timers instead of RTC1
    I am not sure if the second problem is related FreeRTOS?
    I am attaching a patch for SDK12.1, that will make FreeRTOS use RTC2 instead of RTC1, incase you still want to use app_timer.c instead of app_timer_freertos.c, keeping you app functionally same.
    change_freeRTOS_to_use_rtc2_instead_of_rtc1.patch
  • As I see it we have one app_Timer header file and we can select the implementation app_timer.c or app_timer_freertos.c or app_timer_rtx.c by compiling the one we want ( by adding it to the makefile)
    I am currently using app_timer_freertos.c and it is this that has the problem. The problem comes when is run for the second time the freertos timer has already been created and so the handle is not null. The issue is that the timer isnt deleted and there is no way of doing this.
    ble_app_gzll uses the app_timer.c. This isnt creating a new timer when app_timer_create() is called as it is modifying a timer that is already there so I think this is why it works.
    In app_timer_freertos.c if I ignore that error I think it still works as it just uses the timer that was created the first time it was called and luckily the handle is still the same. I have just changed the code to make a delete timer function and this does fix the problem. It will be a major headache implementing this as currently there is no sensible place to run the delete function in the current architecture.
  • Then use the patch and use app_timer.c instead of app_timer_freeRTOS.c . Then you will still have the exact same behavior you had when you were not using FreeRTOS.
  • Ok So here are the fixes for running peer manager when you need to stop and restart the Ble app
    Note: my project is based on the ble_app_hrs_freertos which has been modified to behave like the ble_app_gzll project so that the ble stack can be stoped and started
    1. ble_conn_state_init(); needs to be run on the initialization of the ble. Before the peer manager in initialised. This clears all the flags other wise the pm_init()->gcm_init() can not acquire them.
    ble_app_hrs_freertos: (tested)
    1. Add ble_conn_state_init(); to the static void ble_init(void) function
    ble_app_gzll project: (not tested)
    1. ble_app_gzll_hr.c -> Add ble_conn_state_init(); to the void ble_stack_start(void)function
    • Non urgent as I can fix this myself as it is not part of an SDK library/component.
    2)m_n_registrants needs to be reset to 0 on initialisation. This clears the event handlers and allows new ones to be registered using the pm_register(pm_evt_handler). Other wise each time the peer_manager_init() is run it will register the event again and fill up the buffer.
    Please can a fix\ patch be put in for this. I need a way of setting m_n_registrants to 0. Urgent as it requires a change to the peer manager which is a SDK library/component.
    This could either be done in ret_code_t pm_init(void) or by making a new function to clear events. Im not fussed.
    3)There is now a third issue with the fds module. It is the same scenario as in the peer manager.
    at no point is m_users set to 0! This could be a bug if the memory location at m_users is not 0 on start up!
    in my opinion this should be set to 0 when initialized and in the fds_init() function.
  • Unfortunately I cant do this as we are using the other timers and RTC's.
