It used to work, but now it says "Connected" but the rest of the GUI never changes and the mouse just shows a busy spinner. Here's the log file:
0;13:45:18.9900 [MainThread] Master Control Panel 3.5.0.8226
1;13:45:19.1430 [MainThread] SerialNumberToComport for serial 480108197 returned COM19.
2;13:45:19.1640 [MainThread] HciJLinkDriver opened (COM19, 115200-8-None-1-RequestToSend)
3;13:45:19.1680 [480108197][MainThread] SerialNumberToComport for serial 480108197 returned COM19.
4;13:45:20.1060 [480108197][MainThread] HCI command: BTLE_CMD_READ_BD_ADDR
5;13:45:20.1070 [480108197][MainThread] Serial port write: 01-09-10-00
6;13:45:20.1090 [480108197][MainThread] Waiting for event packet. Timeout is 500ms
7;13:45:20.1100 [480108197][ReadPacketQueueThread] Serial port read: 04-0E-0A-01-09-10-00-56-FF-99-00-CD-29
8;13:45:20.1230 [480108197][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: BTLE_CMD_READ_BD_ADDR, Status: BTLE_STATUS_CODE_SUCCESS, BdAddress: 0x29CD0099FF56
9;13:45:20.1230 [480108197][MainThread] Finished waiting for event packet. PacketReceived:True
10;13:45:20.1270 [480108197][MainThread] HCI command: NRF_CMD_SET_BD_ADDR, Address: 0x53-D1-6D-72-73-73
11;13:45:20.1270 [480108197][MainThread] Serial port write: 01-03-FC-06-53-D1-6D-72-73-73
12;13:45:20.1270 [480108197][MainThread] Waiting for event packet. Timeout is 500ms
13;13:45:20.1290 [480108197][ReadPacketQueueThread] Serial port read: 04-0E-04-01-03-FC-00
14;13:45:20.1290 [480108197][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: NRF_CMD_SET_BD_ADDR, Status: BTLE_STATUS_CODE_SUCCESS
15;13:45:20.1300 [480108197][MainThread] Finished waiting for event packet. PacketReceived:True
16;13:45:20.1310 [480108197][MainThread] HCI command: NRF_CMD_GET_VERSION_INFO
17;13:45:20.1310 [480108197][MainThread] Serial port write: 01-06-FC-00
18;13:45:20.1310 [480108197][MainThread] Waiting for event packet. Timeout is 500ms
19;13:45:20.1360 [480108197][ReadPacketQueueThread] Serial port read: 04-0E-2C-01-06-FC-00-6D-65-66-77-5F-6E-72-66-35-31-38-32-32-5F-30-2E-39-2E-30-2E-31-30-30-32-32-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
20;13:45:20.1370 [480108197][ReadPacketQueueThread] HCI event: BTLE_EVENT_COMMAND_COMPLETE, OpCode: NRF_CMD_GET_VERSION_INFO, Status: BTLE_STATUS_CODE_SUCCESS, VersionInfo: mefw_nrf51822_0.9.0.10022
21;13:45:20.1370 [480108197][MainThread] Finished waiting for event packet. PacketReceived:True
22;13:45:21.5430 [480108197][ScriptThread] Python exception: No module named Nordicsemi
Stacktrace: at Microsoft.Scripting.Runtime.LightExceptions.CheckAndThrow(Object value)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`2.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.Interpreter.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run1[T0,TRet](T0 arg0)
at IronPython.Compiler.RuntimeScriptCode.InvokeTarget(Scope scope)
at IronPython.Compiler.RuntimeScriptCode.Run(Scope scope)
at IronPython.Runtime.PythonContext.InitializeModule(String fileName, ModuleContext moduleContext, ScriptCode scriptCode, ModuleOptions options)
at IronPython.Runtime.PythonContext.CompileModule(String fileName, String moduleName, SourceUnit sourceCode, ModuleOptions options, ScriptCode& scriptCode)
at IronPython.Runtime.Importer.LoadModuleFromSource(CodeContext context, String name, String path)
at IronPython.Runtime.Importer.LoadFromDisk(CodeContext context, String name, String fullName, String str)
at IronPython.Runtime.Importer.ImportFromPathHook(CodeContext context, String name, String fullName, List path, Func`5 defaultLoader)
at IronPython.Runtime.Importer.ImportFromPath(CodeContext context, String name, String fullName, List path)
at IronPython.Runtime.Importer.ImportNestedModule(CodeContext context, PythonModule module, String name, List path)
at IronPython.Runtime.Importer.ImportModuleFrom(CodeContext context, Object from, String name)
at IronPython.Runtime.Importer.ImportModule(CodeContext context, Object globals, String modName, Boolean bottom, Int32 level)
at IronPython.Modules.Builtin.__import__(CodeContext context, String name, Object globals, Object locals, Object fromlist, Int32 level)
at IronPython.Runtime.Importer.ImportLightThrow(CodeContext context, String fullName, PythonTuple from, Int32 level)
at IronPython.Runtime.Operations.PythonOps.ImportWithNames(CodeContext context, String fullName, String[] names, Int32 level)
at Microsoft.Scripting.Interpreter.FuncCallInstruction`5.Run(InterpretedFrame frame)
at Microsoft.Scripting.Interpreter.LightLambda.Run2[T0,T1,TRet](T0 arg0, T1 arg1)
at IronPython.Compiler.PythonScriptCode.RunWorker(CodeContext ctx)
at IronPython.Compiler.PythonScriptCode.Run(Scope scope)
at Microsoft.Scripting.SourceUnit.Execute(Scope scope, ErrorSink errorSink)
at Microsoft.Scripting.Hosting.ScriptSource.Execute(ScriptScope scope)
at Microsoft.Scripting.Hosting.ScriptEngine.ExecuteFile(String path, ScriptScope scope)
at UlpbtIronPython.TesterScript.ScriptRun()
