read back protection puts tag to high current consumption
Hi, I am seeing an issue where after enabling read back protection (rbp) on NRF52 and using sdk 12.1 the tag goes to state where it drains a lot of current.
command used: nrfjprog -f NRF52 --rbp ALL
I have used power profiler to check the behavior, current drain jumps to about ~1.5 mA, from ~120 uA. Since nrfjprog commands are disabled after rbp, issuing a reset command (nrfjprog -f NRF52 --reset) would not help the issue, rather increases the current consumption even higher to about ~3.5 mA (although I see an error message indicating recover command should be used to talk to the chip again, but still the command seems to succeed the first time around and increase current drain even more):
$ nrfjprog -f NRF52 --reset ERROR: The operation attempted is unavailable due to readback protection in ERROR: your device. Please use --recover to unlock the device.
The only way to recover is via a battery pull (pinreset, or debugreset commands also do not seem to fix the issue as the current drain stays high).
Can you please help explain why (and also under what conditions) the chip goes to this state (probably "debug state"?) and how can I recover without a battery pull. I would need to have the rbp enabled and it seems using rbp is only one way the chip could get into this high current drain mode.
**Please help explain other possible conditions that could lead to this high current drain mode.
Thanks.
ppk setup
Parents Reply
  • Hi Stian,
    I added a connection from the reset pin (p0.21 on schematics) to the pin 10 of the J1. I can see that the "nrfjprog -f NRF52 --pinreset" command now works and it initiates a reset when chip is locked (--rbp). However the current stays high still (~3.30 mA, after enabling the read back protection).
    Were you able to confirm the behavior on your side?
    I do not think the command is sent to the power profiler kit. Using voltmeter on the P0.19 (pin22) would show the voltage (around 2.71v) also measuring the current on the same pin would always show a constant value of around 190 uA regardless of debug/normal mode.
    Thanks.
