hrs_rscs_relay sd_ble_gap_adv_data_set error code 00000010
I'm trying to use ble_app_hrs_rscs_relay_pca10056_s140 on a nRF52840 Preview DK using example from SDK 13.0.0_04a0bfd.
When I copy the precompiled .hex file in the file explorer, everything is fine.
I have an issue when I try to build then run the project myself with Segger Embedded Studio v3.26
The Build part works fine. But I have an error in the debug part.
In the advertising_init function, I get an error with code 00000010 when the function ble_advertising_init is called.
I haven't changed anything in the code so far.
Do you have any advice?
EDIT :
Call to sd_ble_gap_adv_set() in debugger: sd_ble_gap_adv_data_set.PNG
Section Placement Macro : FLASH_START=0x24000 SRAM_START=0x20002c50
Thank you
FINAL : I was not using the right sofdevice. s140 v 5.0.0-3alpha is not compatible with SDK 13 at the moment. Works now with :
FLASH_START=0x22000 SRAM_START=0x20002c50
1 2
