CRYS_ECDSA_Verify returns 0x00F00871 [SDK14]
I am trying to use the cryptocell in the bootloader (bootloader_secure_ble) for verifying dfu packages, but fails in signature verification for the same dfu package, same public key as I used with micro-ecc crypto library, where it works as it should.
Comparing the parameters sent to the respective functions, one can see that the hash is reversed, compared to the call to uECC_verify(..), in the call to CRYS_ECDSA_Verify(..). The rest of the parameters are looking the same way, i.e. public_key and signature.
(Tried to make a quick fix by changing the order of the packet_hash received from nrf_crypto_hash_compute(...), but it did not help - verification still fails.). At the bottom, the parameters are attached.
Small note: Function hash_algorithm_get(...) should return true on success and not NRF_SUCCESS (as the result is used as a boolean value in the dfu code).
What do I need to do to make this work?
/Ola.
Attached the parameters sent to the two crypto calls: crys_error = CRYS_ECDSA_Verify(p_verify_context_user, p_public_key_user, hash_mode, p_signature->p_value, p_signature->length, p_hash->p_value, p_hash->length);
p_verify_context_user = NULL p_public_key_user = { 0x99, 0x3F, 0xB3, 0xC5, 0x95, 0x19, 0x1D, 0x9D, 0xCB, 0x05, 0x20, 0xE6, 0xBC, 0x53, 0x5F, 0x7D, 0x00, 0x16, 0x24, 0x76, 0x08, 0xE4, 0xF4, 0xF2, 0x1B, 0xF1, 0x19, 0x55, 0x3F, 0x59, 0x1A, 0x78, 0x8B, 0x4D, 0x02, 0xA9, 0x78, 0x4F, 0x80, 0x16, 0xC2, 0xA0, 0x7C, 0xF0, 0xF9, 0xA1, 0xB3, 0xEB, 0x76, 0x9A, 0x64, 0x79, 0xA6, 0x77, 0x20, 0x33, 0x46, 0x35, 0x2C, 0xD9, 0xFE, 0x54, 0x05, 0xA6, 0x64, 0x66, 0x71, 0x5F, 0x72, 0x65, 0x71, 0x5F, 0x68, 0x61, 0x6E, 0x64, 0x6C, 0x69, 0x6E, 0x67, 0x00, 0x00, 0x00, 0x00, 0xD0, 0x45, 0x00, 0x20, 0x05, 0x00, 0x00, 0x00, 0x04, 0x05, 0x00, 0x00, 0x7C, 0x46, 0x00, 0x20 }; , hash_mode = p_signature->p_value = { 0x9E, 0xB6, 0x63, 0x57, 0x83, 0xAC, 0x46, 0xC0, 0xA7, 0x8C, 0xAB, 0x8E, 0x0F, 0x95, 0xF1, 0xFB, 0xEF, 0x6E, 0x11, 0x23, 0x9C, 0xFD, 0xDC, 0x99, 0x5F, 0x25, 0x77, 0xB5, 0x97, 0x72, 0x04, 0xAE, 0xEE, 0x41, 0x42, 0xF7, 0x62, 0x08, 0xED, 0x81, 0x42, 0x4F, 0x3B, 0xD9, 0xE5, 0xAB, 0xD1, 0x7F, 0xCE, 0x5E, 0xDA, 0x80, 0x5B, 0xAF, 0xB2, 0x4E, 0xDE, 0x47, 0xF0, 0x3F, 0x49, 0xBF, 0xE0, 0x23, 0x01, 0x05, 0x8C, 0x1F, 0x90, 0xBF, 0x99, 0xD2, 0x03, 0xBA, 0x8B, 0xED, 0x80, 0x94, 0x69, 0xD6, 0x49, 0xAD, 0xB5, 0xE7, 0x4D, 0x23, 0xD1, 0xA8, 0x20, 0x56, 0xD6, 0x68, 0xB1, 0x77, 0xF1, 0x4B, 0x00, 0x00, 0x00, 0x00 }; p_signature->length = 64
p_hash->p_value = { 0x01, 0x05, 0x8C, 0x1F, 0x90, 0xBF, 0x99, 0xD2, 0x03, 0xBA, 0x8B, 0xED, 0x80, 0x94, 0x69, 0xD6, 0x49, 0xAD, 0xB5, 0xE7, 0x4D, 0x23, 0xD1, 0xA8, 0x20, 0x56, 0xD6, 0x68, 0xB1, 0x77, 0xF1, 0x4B };
p_hash->length = 32
uECC_verify(p_public_key->p_value, p_hash->p_value, p_hash->length, p_signature->p_value, p_curve);
p_public_key->p_value = { 0x99, 0x3F, 0xB3, 0xC5, 0x95, 0x19, 0x1D, 0x9D, 0xCB, 0x05, 0x20, 0xE6, 0xBC, 0x53, 0x5F, 0x7D, 0x00, 0x16, 0x24, 0x76, 0x08, 0xE4, 0xF4, 0xF2, 0x1B, 0xF1, 0x19, 0x55, 0x3F, 0x59, 0x1A, 0x78, 0x8B, 0x4D, 0x02, 0xA9, 0x78, 0x4F, 0x80, 0x16, 0xC2, 0xA0, 0x7C, 0xF0, 0xF9, 0xA1, 0xB3, 0xEB, 0x76, 0x9A, 0x64, 0x79, 0xA6, 0x77, 0x20, 0x33, 0x46, 0x35, 0x2C, 0xD9, 0xFE, 0x54, 0x05, 0xA6, 0x64, 0x66, 0x71, 0x5F, 0x72, 0x65, 0x71, 0x5F, 0x68, 0x61, 0x6E, 0x64, 0x6C, 0x69, 0x6E, 0x67, 0x00, 0x00, 0x00, 0x00, 0xD0, 0x45, 0x00, 0x20, 0x05, 0x00, 0x00, 0x00, 0x04, 0x05, 0x00, 0x00, 0x7C, 0x46, 0x00, 0x20 };
p_hash->p_value = { 0x4B, 0xF1, 0x77, 0xB1, 0x68, 0xD6, 0x56, 0x20, 0xA8, 0xD1, 0x23, 0x4D, 0xE7, 0xB5, 0xAD, 0x49, 0xD6, 0x69, 0x94, 0x80, 0xED, 0x8B, 0xBA, 0x03, 0xD2, 0x99, 0xBF, 0x90, 0x1F, 0x8C, 0x05, 0x01 }; p_hash->length = 32
p_signature->p_value = { 0x9E, 0xB6, 0x63, 0x57, 0x83, 0xAC, 0x46, 0xC0, 0xA7, 0x8C, 0xAB, 0x8E, 0x0F, 0x95, 0xF1, 0xFB, 0xEF, 0x6E, 0x11, 0x23, 0x9C, 0xFD, 0xDC, 0x99, 0x5F, 0x25, 0x77, 0xB5, 0x97, 0x72, 0x04, 0xAE, 0xEE, 0x41, 0x42, 0xF7, 0x62, 0x08, 0xED, 0x81, 0x42, 0x4F, 0x3B, 0xD9, 0xE5, 0xAB, 0xD1, 0x7F, 0xCE, 0x5E, 0xDA, 0x80, 0x5B, 0xAF, 0xB2, 0x4E, 0xDE, 0x47, 0xF0, 0x3F, 0x49, 0xBF, 0xE0, 0x23, 0x4B, 0xF1, 0x77, 0xB1, 0x68, 0xD6, 0x56, 0x20, 0xA8, 0xD1, 0x23, 0x4D, 0xE7, 0xB5, 0xAD, 0x49, 0xD6, 0x69, 0x94, 0x80, 0xED, 0x8B, 0xBA, 0x03, 0xD2, 0x99, 0xBF, 0x90, 0x1F, 0x8C, 0x05, 0x01, 0x00, 0x00, 0x00, 0x00 }; p_curve = 08 20 00 01 FF FF ...
  • Hi Ola,
    the error code 0x000F00781 corresponds to CRYS_ECDSA_VERIFY_INVALID_USER_CONTEXT_PTR_ERROR. Hence its the
    CRYS_ECDSA_VerifyUserContext_t * p_verify_context_user = NULL;
    line in nrf_crypto_ecdsa_verify_hash() that is the cause of the error. I discussed this with one of the SW developers responsible for the Cryptocell libraries and its been declared as a null pointer intentionally. This pointer should have been passed as an argument to the nrf_crypto_ecdsa_verify_hash() function, containing the results from the previously called nrf_crypto_hash_compute() function. However, there was not enough time to implement this prior to the release of the SDK.
    Furthermore, the CC310_keil_0.9.0.lib much larger than we would like, so we're in the process looking into how we can reduce the code size and we're also re-writting the nrf_crypto library.
    Thus, I would not spend to much time on this as it will most likely change significantly once the CryptoCell library and the nrf_crypto libraries are production-ready.
    Best regards Bjørn
  • Hi Ola,
    Best regards Bjørn
