Why can not set MAX_MTU_SIZE to 247?
On 52832, SDK V14.0.0, SD132-5.0
I tried to set NRF_SDH_BLE_GATT_MAX_MTU_SIZE to 247, as from dev-doc i saw that SD132 supports BLE V4.2 DLE.
However it returns:
ble_gatt: sd_ble_gap_data_length_update() (request) on connection 0x0 returned unexpected value 0x13.
When set MAX_MTU_SIZE to 23 this issue disappear.
  • @Petter Myhre
    Thank you for replying.
    I managed to resolve it, at least it looks to. I probably misunderstood the error message, it does not have to be local resource limitation, but from limitations in peer device.
    Not using a specific example mixed with my own codes. 52 is acting as peripheral of a iPad Air 2, which according to Apple it supports v4.2. I had thought it is due to 52 local setting limits so i reverted to 23, how ever when I turned on debug log immediately i saw iPad is requesting for a packet length of 185 - i think that's why i can not set PDU size to 247 - as iPad may refuse it, probably because its support of V4.2 is partial.
    So in the end as a solution i added PDU size exchange response of 247 to peer's request - as i still have 247 set in SDK_config.h. I still got the same error message but this action seems completed the negotiation procedure and PDU size ends up be set to 185.
    LOG:
    ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
    ble_gatt: Requesting to update data length to 251 on connection 0x0.
    ble_gatt: ATT MTU updated to 185 bytes on connection 0x0 (response).
    Hope i am understanding the process correctly.
  • One question i would like to clarify: is ATT MTU size defined here identical to physical layer packet length? As from the above log, i can see that though ATT MTU is 185, but (physical) data length is actually 27? Is there anyway that i can check the size of physical layer packet size?
    I do successfully transfer a packet of 43 bytes in one call but i am not sure if that is because SD does the auto segmentation / re-assemble work that is transparent to me.
