I'm using a nrf52 custom board based out of the telit bluemod s42. I'm trying to port the ble_app_uart example of the SDK14 onto the custom board. The code seems to be getting stuck at the function nrf_sdh_enable_request(void) present in the ble_stack_init function.
nrf_sdh_enable_request(void) is shown below :
ret_code_t nrf_sdh_enable_request(void)
ret_code_t ret_code;
if (m_nrf_sdh_enabled)
m_nrf_sdh_continue = true;
// Notify observers about SoftDevice enable request.
if (sdh_request_observer_notify(NRF_SDH_EVT_ENABLE_REQUEST) == NRF_ERROR_BUSY)
// Enable process was stopped.
return NRF_SUCCESS;
// Notify observers about starting SoftDevice enable process.
sdh_state_observer_notify(NRF_SDH_EVT_STATE_ENABLE_PREPARE);
nrf_clock_lf_cfg_t const clock_lf_cfg =
.source = NRF_SDH_CLOCK_LF_SRC,
.rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV,
.rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV,
#ifdef S132
.accuracy = NRF_SDH_CLOCK_LF_XTAL_ACCURACY
#else
.xtal_accuracy = NRF_SDH_CLOCK_LF_XTAL_ACCURACY
#ifdef ANT_LICENSE_KEY
ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler, ANT_LICENSE_KEY);
#else
ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler);
if (ret_code != NRF_SUCCESS)
return ret_code;
m_nrf_sdh_enabled = true;
m_nrf_sdh_continue = false;
m_nrf_sdh_suspended = false;
// Enable BLE event interrupt (interrupt priority has already been set by the stack).
#ifdef SOFTDEVICE_PRESENT
ret_code = sd_nvic_EnableIRQ((IRQn_Type)SD_EVT_IRQn);
return ret_code;
#else
//In case of serialization, NVIC must be accessed directly.
NVIC_EnableIRQ(SD_EVT_IRQn);
// Notify observers about a finished SoftDevice enable process.
sdh_state_observer_notify(NRF_SDH_EVT_STATE_ENABLED);
return NRF_SUCCESS;
Program was getting stuck at the ret_code = sd_softdevice_enable(&clock_lf_cfg, app_error_fault_handler); I then changed the clk settings to :
Now the code jumps to
return NRF_SUCCESS;
after executing statement :
and is stuck in the nrf_sdh_enable_request(void) function.
Could you please let me know if any other configuration changes are required to run the softdevice. I'm using softdevice v 5.0.0 which came with the sdk 14.0.0
