NFC url with ble_stack
Hi all,
I'm working on a implementation of the nfc url to my custom nrf52832 product.
I would like to run the record_url example on my custom application. I made a library which is basically the same code as the example :
err_code = nfc_t2t_setup(nfc_callback, NULL);
VERIFY_SUCCESS(err_code);
uint32_t len = sizeof(m_ndef_msg_buf);
// Encode URI message into buffer
err_code = nfc_uri_msg_encode(NFC_URI_HTTP_WWW,
                               m_url,
                               sizeof(m_url),
                               m_ndef_msg_buf,
                               &len);
// Set created message as the NFC payload
err_code = nfc_t2t_payload_set(m_ndef_msg_buf, len);
err_code = nfc_t2t_emulation_start();
This is perfectly working alone. Let me explain : When I launch my code with only NFC, it's works ! But when I add "ble_stack_init()", the nfc seems to stop working.
ble_stack_init() :
uint32_t ram_start = 0;
// Enable BLE stack.
NRF_SDH_BLE_OBSERVER(m_ble_observer, APP_BLE_OBSERVER_PRIO, on_ble_evt, NULL);
On debug, I have nfc init and start ok! But when I come with the polling device, the library says : "nfc_hal: Reinitialize".
Do you have any ideas of what can cause that ? Maybe the ble stack is stoping HFCLK ? CLOCK_ENABLED is correctly define.
Thanks in advance for your help.
  • Hi, yes SOFTDEVICE_PRESENT is already defined.
    The driver is working (so I believe, all macros are correctly defined for the NFC driver). The problem is, when I Initialize the ble_stack, the NFC driver is not working anymore.
    At this moment, if I add HAL_NFC_ENGINEERING_BC_FTPAN_WORKAROUND to my global definitions, I don't get any messages in the log except : init ok, start ok and when I bring the poller device the message is ([NFC_HAL]: reinitialize) and it seems to be in a loop. The is no message like field_dtetected, sent, ...
