Thingy 52 GCC make error
Following the guide found at : file:///C:/Github/STIWHN/SDK_thingy52/thingy_sdk_v2.1.0/documentation/firmware_compile.html#compile_gcc
I still getting errors trying to build the thingy52 FW
C:\Github\STIWHN\SDK_thingy52\thingy_sdk_v2.1.0\project\pca20020_s132\armgcc>make -j
rm -rf _build
process_begin: CreateProcess(NULL, rm -rf _build, ...) failed.
make (e=2): The system cannot find the file specified.
Makefile:397: recipe for target 'clean' failed
make: *** [clean] Error 2
I checked the makefile.windows it is configured as following:
GNU_INSTALL_ROOT := C:/Program Files (x86)/GNU Tools ARM Embedded/4.9 2015q3
GNU_VERSION := 4.9.3
GNU_PREFIX := arm-none-eabi
The path in windows to the GNU tools :
C:\Program Files (x86)\GNU Tools ARM Embedded\4.9 2015q3
The project found in 'thingy_sdk_v2.1.0\project\pca20020_s132' also does not build in Keil or in Segger.
Any help would be great.
  • Do you have "rm" installed? Looks like the syscall to rm fails with command not found. "rm" should be in the coreutils package from GNU, and it needs to be in your PATH.
  • Hey ToasTer86. Did Håkon's tips help you fix the problem?
  • Hey Bjørn,
    I thought coreutils was part of the standard GNUwin32 package, but it is not. So to make the Thingy52 project files you have to also install the coreutils package by GNUwin. It could be usefull to add this to the guide, although it might have just been my own incompetence.
    Assembly file: gcc_startup_nrf52.S
    Linking target: nrf52832_xxaa_s132.out
    make[1]: Entering directory 'C:/Github/STIWHN/SDK_thingy52/thingy_sdk_v2.1.0/project/pca20020_s132/armgcc'
    Preparing: nrf52832_xxaa_s132.bin
    Preparing: nrf52832_xxaa_s132.hex
       text    data     bss     dec     hex filename
     186240     380   19780  206400   32640 _build/nrf52832_xxaa_s132.out
    make[1]: Leaving directory 'C:/Github/STIWHN/SDK_thingy52/thingy_sdk_v2.1.0/project/pca20020_s132/armgcc'
    Above is my result from building the project. Thanks for checking up, I should have posted an update here.
  • Great! I will forward this feedback to the relevant people in Nordic.
