pm_conn_sec_status_get bug?
phenomenon:
When master successfully encrypts using previous binding information, pm_evt_handler in main.c receives a PM_EVT_CONN_SEC_SUCCEEDED event and gets a bonded state of 0 using pm_conn_sec_status_get.
My point is:
After the master has successfully encrypted using the previous binding information, the slave should also be in the bonded state. By looking at peer_manager.c, since the above process is considered PM_LINK_SECURED_PROCEDURE_ENCRYPTION, the bonded flag is not set in pm_sm_evt_handler
Is it my understanding wrong? If I did not understand it, how to fix it?
  • No problem. The bonded flag is also set when PM_EVT_BONDED_PEER_CONNECTED. The bug in this case is that the PM_LINK_SECURED_PROCEDURE_ENCRYPTION event is overwriting the flag from 1 to 0.
    It might be more intuitive if you do
    if (!ble_conn_state_user_flag_get(p_sm_evt->conn_handle, m_bonded_flag_id))
        ble_conn_state_user_flag_set(p_sm_evt->conn_handle, m_bonded_flag_id, bonded);
    instead, but the result should be the same.
