How to know which physical device is disconnected in disconnect event?
Here the connect method is called
err_code =
	sd_ble_gap_connect(
		peer_addr,
		&m_scan_params,
		&m_connection_param,
		APP_BLE_CONN_CFG_TAG);
In the ble event handler there is the event BLE_GAP_EVT_DISCONNECTED
    // ... other events
		NRF_LOG_INFO("LBS central link 0x%x disconnected (reason: 0x%x)",
		p_gap_evt->conn_handle,
		p_gap_evt->params.disconnected.reason);
		if (ble_conn_state_n_centrals() == 0)
			err_code = app_button_disable();
			// Turn off connection indication LED
			bsp_board_led_off(CENTRAL_CONNECTED_LED);
		// Start scanning
		scan_start();
		// Turn on LED for indicating scanning
		bsp_board_led_on(CENTRAL_SCANNING_LED);
	} break;
	// ... other events
I'm wondering how I can know with some unique identifer which device is being discconected.
For example, I have my tablet connected to the NRF and also some other NRF peripherals.
So when tablet disconnects, BLE_GAP_EVT_DISCONNECTED case is triggered.
How can I know my tablet is discconected? I have tried parsing advertising data for device name, and I know first data element is device name.
I have added this code to the case statement
bool is_tablet = is_tablet_or_not(p_ble_evt);
if(is_tablet){
	log("is_tablet is true");
	tabletDisconnected = true;
} else {
	log("is_tablet is false");
	tabletDisconnected = false;
But advertisment data in is_tablet_or_not is not there anymore
static bool is_tablet_or_not(ble_evt_t const * p_ble_evt){
	log("is_tablet_or_not");
	ble_gap_evt_adv_report_t adv_report =
	    p_ble_evt->evt.gap_evt.params.adv_report;
	int name_length = adv_report.data[1]; // idx 1 is type idx 2 is length
	logIntWithMessage("type is ",adv_report.data[0]);   // logs "type is 0"
	logIntWithMessage("length is ",adv_report.data[1]); // logs "length is 0"
	char name[name_length];
	for(int i = 2; i < 2 + name_length; i++){
		name[i] = adv_report.data[i];
	logStrWithMessage("name is ",name);
	// strcmp returns 0 when two strings are equal
	bool is_tablet_name = (strcmp(name,"Tablet") == 0);
	if(is_tablet_name){
		return true;
		return false;
Can I use advertisment data to parse for device name again, or can I used some other identifier to know if my tablet is disconnected?
  • The only identifier of the connection link is connection handle. Once you ask GAP layer to initiate connection at that moment you know what MAC/device name/whatever proprietary ID you are try to connect to. So once the link is established and you get BLE_GAP_EVT_CONNECTED you can associate this link/handle with any other information you got before (typically through advertising/scanning) if you want, it's you business, just do it in your application logic.
    This question looks to me like duplicate of this: devzone.nordicsemi.com/.../
