what actual status is NRF_ERROR_INVALID_STATE from sd_ble_gattc_primary_services_discover?
I'm using SDK13.0.0 ble_app_ancs_c example.
On connected with a phone, pm_evt_handler is called with PM_EVT_CONN_SEC_SUCCEEDED, and call ble_db_discovery_start(), then it sometimes get NRF_ERROR_INVALID_STATE.
I add a log in the ble_db_discovery_start(), and I found sd_ble_gattc_primary_services_discover() in the ble_db_discovery_start() returns NRF_ERROR_INVALID_STATE.
I have checked the document about sd_ble_gattc_primary_services_discover, and it says NRF_ERROR_INVALID_STATE means Invalid Connection State. What state is Invalid Connection State actually ? How can I avoid the state?
Below is the pm_evt_handler in ble_app_ancs_c main.c.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t ret;
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_DEBUG("Connected to previously bonded device");
            m_peer_id = p_evt->peer_id;
        } break; // PM_EVT_BONDED_PEER_CONNECTED
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
            // Note: You should check on what kind of white list policy your application should use.
            if (p_evt->params.conn_sec_succeeded.procedure == PM_LINK_SECURED_PROCEDURE_BONDING)
                NRF_LOG_DEBUG("New Bond, add the peer to the whitelist if possible");
                NRF_LOG_DEBUG("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",
                               m_whitelist_peer_cnt + 1,
                               BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
                if (m_whitelist_peer_cnt < BLE_GAP_WHITELIST_ADDR_MAX_COUNT)
                    // Bonded to a new peer, add it to the whitelist.
                    m_whitelist_peers[m_whitelist_peer_cnt++] = m_peer_id;
                    m_is_wl_changed = true;
            // Discover peer's services.
            memset(&m_db_disc, 0x00, sizeof(m_db_disc));
            ret  = ble_db_discovery_start(&m_db_disc, p_evt->conn_handle);
            APP_ERROR_CHECK(ret);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            ret = fds_gc();
            if (ret == FDS_ERR_BUSY || ret == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            advertising_start(false);
        } break;
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // The local database has likely changed, send service changed indications.
            pm_local_database_has_changed();
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
  • I got the message from other Nordic employee like below.
    Sometimes it may occur that the central send a connection request, but that the connection is not established. The application will experience connection event and then a disconnect event. If you call sd_ble_gattc_primary_services_discover() then you may get NRF_ERROR_INVALID_STATE.\
    In this specific case you may ignore the error yes, since the sd_ble_gattc_primary_services_discover() will trigger on next connection event in any case.
    Thank you.
    Thank you.
