Segger Embedded Studio outputs different then expected .hex file
I'm trying to port Thingy52 firmware project from Keil to SES.
I followed this guide Segger Embedded Studio - A Cross Platform IDE
I manage to build without any errors but programming the device doesn't run the project.
I compared SES output .hex with Keil output .hex and they are different.
SES file size is 590kb, Keil file size is 426kb.
SES file starts at address 0x1000F000 instead of 0x0001F000 like in Keil and in flash_placement.xml and MemoryMap.xml.
SES .hex file seems to start at that address regardless of my modifications.
Anyone managed to build a successful Thingy52 output from SES?
Thanks, Eyar
  • Welcome to the world of ANSI C compilers and linkers;) Yes, different build chain means different output, this is expected. Nordic uses one toolchain to provide reference binaries (usually HEX files) and it used to be IAR, not sure if it is still true with nRF5 SDK v14.x and Thingy. But it should be written in release notes. This doesn't mean that any of these HEX files won't work! If you have correct source code and correctly configured compilation chain they should be both fine. It's just different level of optimizations and other tricks which make binaries different, some tools are more expensive and promise smaller code size, RAM footprint or faster execution, some are simply open source and free but they can be pretty competitive nowadays. It's up to you what are your priorities and budget.
  • The start address looks wrong and there might be some other reasons. When I quickly looked on the blog post about how to set-up the project in SES it's fairly long (and also mentions how to set ROM and RAM start addresses). Are you sure that you haven't done any mistake and that all is aligned with Soft Device version you use?
