Hi all,
I am trying to control a speaker using the i2s output of the nrf52832 mapped into a TAS2505 from TI. I am able to play sounds in the speaker but my issue is that as I am sending the audio data blocks after blocks, the sounds is also played blocks after blocks with little time gaps between the blocks. As I have limited RAM size I cannot send the sound I want to play in only one block!
So my question is how can I send continuously data through I2S?
Below you will find the code I am using right now where test is a tab of bytes with the sound I want to play :
// This is the I2S data handler - all data exchange related to the I2S transfers // is done here.
static void data_handler(uint32_t const * p_data_received,
uint32_t * p_data_to_send,
uint16_t number_of_words)
// Non-NULL value in 'p_data_to_send' indicates that the driver needs
// a new portion of data to send.
if (p_data_to_send != NULL)
// Here we write the provided buffer with consecutive 16-bit values
// in order to be able to check later if they were transmitted properly.
//prepare_tx_data(p_data_to_send, number_of_words);
++m_blocks_transferred;
uint16_t i;
for(i=0;i<I2S_BUFFER_SIZE;i++){
m_buffer_tx[i]=(uint32_t)(test[I2S_BUFFER_SIZE*m_blocks_transferred+i*4]<<24)+(uint32_t)(test[I2S_BUFFER_SIZE*m_blocks_transferred+i*4+1]<<16)+(uint32_t)(test[I2S_BUFFER_SIZE*m_blocks_transferred+i*4+2]<<8)+(uint32_t)(test[I2S_BUFFER_SIZE*m_blocks_transferred+i*4+3]<<0);
void main()
uint32_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("I2S loopback example\r\n");
nrf_drv_i2s_config_t config = NRF_DRV_I2S_DEFAULT_CONFIG;
config.sdin_pin = 3;//TAS2505_DATA_PIN;
config.sdout_pin = TAS2505_DATA_PIN;
config.mck_setup = I2S_CONFIG_MCKFREQ_MCKFREQ_32MDIV63;
config.ratio = I2S_CONFIG_RATIO_RATIO_32X;
config.channels = I2S_CONFIG_CHANNELS_CHANNELS_Left;//NRF_I2S_CHANNELS_STEREO;
err_code = nrf_drv_i2s_init(&config, data_handler);
m_blocks_transferred = 0;
err_code = nrf_drv_i2s_start(NULL, m_buffer_tx,
I2S_BUFFER_SIZE, 0);
while (m_blocks_transferred < BLOCKS_TO_TRANSFER)
nrf_drv_i2s_stop();
Thanks in advance,
Sylvain
