Acknowledged message re-transmit time
I'm currently investigating the Bluetooth mesh using the SDK for mesh alpha 0.10.0, I was wondering about the limitations on the re-transmission of messages. The current equation for calculating the re-transmit of messages is as follows,
uint32_t interval = (ttl * ACCESS_RELIABLE_HOP_PENALTY) + ACCESS_RELIABLE_INTERVAL_DEFAULT;
this is doubled every time a packet is acknowledged until the timeout period (set at 30s by the Bluetooth spec) using:
m_reliable.pool[i].interval *= ACCESS_RELIABLE_BACK_OFF_FACTOR;
where ACCESS_RELIABLE_BACK_OFF_FACTOR is set to 2.
Does the Bluetooth spec limit the back off factor at 2 or can it be reduced to increase the rate of re-transmission?
Alternatively, could the ACCESS_RELIABLE_HOP_PENALTY or ACCESS_RELIABLE_INTERVAL_DEFAULT be reduced or again does the Bluetooth spec require this to be set the same as the BEARER_ADV_INT_DEFAULT_MS?
Will this also be affected by the Radio Equipment Directive (RED) 2014/53/EU requiring efficient use of the radio spectrum?
Richard
