do sd_flash_page_erase or sd_flash_write provide any guarantees that the command has executed successfully or should I do a manual check to verify if the page was really erased or the data was written correctly?
Thanks, Marius
Thanks, Marius
You mean like, when you call sd_flash_write(...), it will write the data in NVM and then read it back and compare it to the original data and make sure it was written correctly? My assumption is no, but I am also curious to know if it does that! Let's hear from a Nordic...
Yes, that's what I want to know. Will it return SUCCESS even when the data hasn't been correctly written.
There is no automatic verification of flash content (sd_flash_page_erase /sd_flash_write will not read back the data), so this is something you can add if you want (though I have not heard of this being a problem, and we don't do that ourselves).
Thanks, so you think this could only happen if the flash is corrupt after too many erase cycles? And there will be no possibility that it works the second time?
If you look at the nvmc_driver functions, they always return SUCCESS..
