In s210 there are functions sd_flash_page_erase, sd_flash_protect, and sd_flash_write. There is no sd_flash_read.
How do I read from flash? I can write to is using sd_flash_write, but how do I later read this data?
The S110 stack provides a pstorage API that uses the sd_flash functions. I took a look at the function used to get data out of flash and it is merely using a memcpy call to get the data out of the program space. I'd guess you can do the same with the S210 stack.
I've found (using the Keil debugger) that my problem is writing to flash, not reading from.
I'm doing this:
uint32_t pg_size = NRF_FICR->CODEPAGESIZE;
uint32_t pg_num = NRF_FICR->CODESIZE - 1;
uint32_t *addr;
addr = (uint32_t *)(pg_size * pg_num);
sd_flash_write(addr, flashList, 4);
Where flashList is an integer array of stuff I want to write to the flash. Those first few lines come from the flash example.
However, when I check the location in memory pointed at by addr in the debugger, I get all FFs, which is probably why flash read is seeming not work (giving all Fs).
Any ideas?
I can suggest a couple of things to try:
