Unable to trigger bsp_event_handler when press button
I am writing a program that waits for Button 1 to be pressed. Once it is press, then it will call the function blecomm() in another c file. My code is as below:
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "boards.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "nrf_gpio.h"
#include "nrf_error.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "SEGGER_RTT.h"
#define NRF_LOG_USES_RTT 1
#define DEVICE_NAME                     "Main"
#define MANUFACTURER_NAME               "NordicSemiconductor"
#define APP_TIMER_PRESCALER             0                                           /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE         4                                           /**< Size of timer operation queues. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
void blecomm();
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    // Prepare wakeup buttons.
 * @param[in]   event   Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
	SEGGER_RTT_printf(0, "bsp_event_handler function");
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
            break; // BSP_EVENT_SLEEP
        case BSP_EVENT_KEY_0:
        	SEGGER_RTT_printf(0, "Button 1 is pressed!\n");
        	blecomm();
        case BSP_EVENT_KEY_1:
        	SEGGER_RTT_printf(0, "Button 2 is pressed!\n");
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for application main entry.
    uint32_t err_code;
    bool     erase_bonds;
    // Initialize.
    err_code = NRF_LOG_INIT(NULL);
    timers_init();
    SEGGER_RTT_printf(0, "Template started\r\n");
    nrf_gpio_pin_toggle(LED_1);
    // Enter main loop.
    while(true){
    	 SEGGER_RTT_printf(0, "in loop \n");
            SEGGER_RTT_printf(0, "false\n");
        } else{
        	SEGGER_RTT_printf(0, "true\n");
//    for(;;){
//    	SEGGER_RTT_printf(0, "for loop\n");
When running this, it enters the while loop but when I press Button 1 on Nordic nRF51dk, it does not enter into the 'bsp_event_handler' function. What am I doing wrong here?
(Function blecomm() needs to be triggered upon Button 1 press)
I am using S130 with nRF51DK and Eclipse IDE.
