Question about SPI transaction manager
Some problems I meet when I try to use spi manager in ble_template example to read "who_am_i" register of LIS2DH12. The environment is set as below:
  1. nRF52832 DevelopKit with SDK 14.1.0, ble_app_template project.
  2. Connect the DevelopKit board to LIS2DH12 board with following pin map
    PIN0.03 -> LIS SCK
    PIN0.04 -> LIS SDI/SDA/SDO
    PIN0.28 -> LIS SDO/SA0
    PIN0.29 -> LIS CS
  3. Add following functions in the main.c in the project
    static void accl_spi_transfer_done_cb(ret_code_t result, void * p_user_data)
    	bsp_board_led_on(BSP_BOARD_LED_2);
    static ret_code_t init_spi2_master(void)
    	// SPI2 (with transaction manager) initialization
    	nrf_drv_spi_config_t const m_master2_config =
    		.sck_pin		= ARDUINO_A0_PIN,
    		.mosi_pin		= ARDUINO_A1_PIN,
    		.miso_pin		= ARDUINO_A2_PIN,
    		.ss_pin			= ARDUINO_A3_PIN,
    		.irq_priority	= SPI_DEFAULT_CONFIG_IRQ_PRIORITY,
    		.orc			= 0xFF,
    		.frequency		= NRF_DRV_SPI_FREQ_4M,
    		.mode			= NRF_DRV_SPI_MODE_0,
    		.bit_order		= NRF_DRV_SPI_BIT_ORDER_MSB_FIRST
    	return nrf_spi_mngr_init(&m_nrf_spi_mngr, &m_master2_config);
    static void read_accl_info(void)
    	ret_code_t ret_val;
    	uint8_t tx_cmd[] = {0x8F, 0xFF};
    	nrf_spi_mngr_transfer_t const transfer[] =
    		NRF_SPI_MNGR_TRANSFER(tx_cmd, sizeof(tx_cmd), &rx_data, sizeof(rx_data))
    	nrf_spi_mngr_transaction_t const trans[] =
    			.begin_callback		 = NULL,
    			.end_callback		 = accl_spi_transfer_done_cb,
    			.p_user_data		 = NULL,
    			.p_transfers		 = &transfer[0],
    			.number_of_transfers = 1,
    			.p_required_spi_cfg  = NULL
    	ret_val = nrf_spi_mngr_schedule(&m_nrf_spi_mngr, &trans[0]);
    	APP_ERROR_CHECK(ret_val);
  4. Put the initialization function and read_accl_info function after ble_stack_init() function.
  5. Open SPI_MNGR, NRF_QUEUE and SPI_ENABLE in sdk_config.h
  6. Add following defines in the head of main.c
    #define ACCL_SPI_QUEUE_LENGTH			5
    #define ACCL_SPI_INSTANCE_ID			0
    NRF_SPI_MNGR_DEF(m_nrf_spi_mngr, ACCL_SPI_QUEUE_LENGTH, ACCL_SPI_INSTANCE_ID);
    static uint8_t rx_data[2];
Result, the program is seem to be stuck at read_accl_info function. If I comment it, the program runs successfully. I try to add some breakpoints and run into that function, but every thing is ok, the return value is NRF_SUCCESS. I hope that some one can give me some suggestions. Thanks a lot!
main.c
