Hex file compiled by GCC not working
I have a custom board with the nRF51822 QFAA. Schematic:
image description
In order to compile the firmware, I'm using MinGW. As you can see, I'm also using the SDK 12.3.0.
image description
Finally, in order to upload the .hex generated by the Makefile in /_build, I'm using SEGGER J-Flash Lite:
image description
Until here, everything works fine (Perfect compilation + programming). But the program is not working at all. I chose the ble_app_hrs example.
In order to debug, as I have 2 LEDs, I tried to do a simple blinking at the beginning of the main:
int main(void){
uint32_t err_code;
bool     erase_bonds;
nrf_gpio_cfg_output(28);
nrf_gpio_cfg_output(30);
nrf_gpio_pin_clear(30);
nrf_gpio_pin_clear(28);
	for(;;){
		nrf_delay_ms(500);
		nrf_gpio_pin_set(30);
		nrf_gpio_pin_set(28);
		nrf_delay_ms(500);
But still, It's not working. I've already spent a long time with this and I'm running out of ideas. Could somebody possibly propose me a solution for this?
Parents Reply
  • Tryied your file with my custom board but the LEDs were not making light. Then I tried with the nrf51 DK and test it with an oscilloscope as you can see here: link text. But no signal, 28 and 30 stay at GND level.
    The procedure I followed is the same I used for my board. Downloaded the file; Erased the device with J Flash Lite (with my board I used SEGGER programmer, with DK the USB cable directly); and Program app_with_SD_combined.hex with J Flash. Can I be doing something wrong in these steps?
