Hello guys.
I am able to save an array to flash memory unfortunately I can not save a struct in flash. I am referring to this question Save struct to flash . However I am not able to save it using that example. Where I am doing a mistake in here?
This is my structure:
__align(4) struct
uint8_t sleep_time_min;
uint8_t advertise_time_sec;
}default_commands;
This is pstorage initialization function:
void my_pstorage_init(void)
uint32_t err_code;
pstorage_module_param_t param;
param.block_size = 40; //Select block size of 32 bytes
param.block_count = 1; //Select 2 blocks, total of 64 bytes
param.cb = my_pstorage_cb_handler; //Set the pstorage callback handler
err_code = pstorage_init();
err_code = pstorage_register(¶m, &base_handle);
This is clearing function:
void my_pstorage_clear(void)
pstorage_handle_t block_handle;
uint8_t index;
uint32_t err_code;
index = 0; //we will write to the second block
err_code = pstorage_block_identifier_get(&base_handle, index,&block_handle);
err_code = pstorage_clear(&block_handle,40);
pstorage_wait_handle = block_handle.block_id; //Specify which pstorage handle to wait for
pstorage_wait_flag = 1; //Set the wait flag. Cleared in the my_pstorage_cb_handler
while(pstorage_wait_flag) { power_manage(); } //Sleep until clear operation is finished.
Write function:
void my_pstorage_write(void)
uint8_t index;
uint32_t err_code;
index = 0; //we will write to the first block
//Store data to blocks or just block. Wait for the last store operation to finish before reading out the data.
err_code = pstorage_store(&block_handle, (uint8_t*)&default_commands,sizeof(default_commands),0); //Write to flash, only one block is allowed for each pstorage_store command
while(pstorage_wait_flag) { power_manage(); } //Sleep until store operation is finished.
My main function:
default_commands.sleep_time_min = 1;
default_commands.advertise_time_sec = 30;
my_pstorage_init();
my_pstorage_clear();
my_pstorage_write();
my_pstorage_read();
EDIT______________________________________________________________ So the problem is that microcontroler becomes unresponsive in this case PSTORAGE_STORE_OP_CODE when reaches line retval = sd_flash_write();
case PSTORAGE_STORE_OP_CODE:
uint32_t size;
uint32_t offset;
uint8_t * p_data_addr = p_cmd->p_data_addr;
offset = (m_round_val * SOC_MAX_WRITE_SIZE);
size = p_cmd->size - offset;
p_data_addr += offset;
storage_addr += (p_cmd->offset + offset);
if (size < SOC_MAX_WRITE_SIZE)
retval = sd_flash_write(((uint32_t *)storage_addr),
(uint32_t *)p_data_addr,
size / sizeof(uint32_t));
