Hi everyone,
I am trying to port freertos on the nRF52832, but it is blocked in the vPortSuppressTicksAndSleep function. Below is the code for configuring the system and the freertos:
* Config hardware peripherals
ConfigSystem();
UARTFlush();
* Config FreeRTOS
xMutex = xSemaphoreCreateBinary();
if(xTaskCreate(TaskTest1, "Task 1", configMINIMAL_STACK_SIZE, NULL, 1, NULL) != pdPASS)
SystemRunOutOfMemory();
if(xTaskCreate(TaskTest2, "Task 2", configMINIMAL_STACK_SIZE, NULL, 1, NULL) != pdPASS)
* Activate deep sleep mode
SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
// Start FreeRTOS scheduler.
vTaskStartScheduler();
while(1)
PrintError("Forbidden for RTOS status!");
UARTFlush();
void TaskTest1(void * pvParameter)
while(1)
xSemaphoreTake(xMutex, portMAX_DELAY);
PrintDebug("Task 1");
UARTFlush();
xSemaphoreGive(xMutex);
vTaskDelay(1);
void TaskTest2(void * pvParameter)
while(1)
PrintDebug("Task 2");
UARTFlush();
vTaskDelay(1);
PrintDebug function:
void PrintDebug(const char *string, ...)
volatile char txBuf[100];
DEBUG_HEADER();
va_list arg;
memset((void *) txBuf, 0, sizeof(txBuf));
va_start(arg, string);
vsprintf((char *) txBuf, string, arg);
va_end(arg);
UARTWrite((uint8_t *) txBuf, strlen((const char *) txBuf));
COLOR_ENDL();
UART_ERR_CODE_t UARTWrite(uint8_t *pByte, uint8_t length)
UART_ERR_CODE_t errCode = UART_ERR_SUCCESS;
// Write bytes to TX buffer
errCode |= WriteToTXBuff(pByte, length);
return errCode;
static UART_ERR_CODE_t WriteToTXBuff(uint8_t *byte, uint8_t length)
UART_ERR_CODE_t err = UART_ERR_SUCCESS;
// If TX buffer is full, return error code
if(controlBlock.txBufferAvailable == 0)
return UART_ERR_BYTES_ABORTED;
// Write bytes to TX buffer until TX buffer is full or all bytes are transmitted
while((controlBlock.txBufferAvailable != 0) && (length != 0))
if(xQueueSendToBack(txBuffer, ( void * )byte, (TickType_t) 0) != pdPASS)
byte++;
controlBlock.txBufferAvailable--;
length--;
if((controlBlock.txBufferAvailable == 0) && (length != 0))
err |= UART_ERR_BYTES_ABORTED;
return err;
The code is blocked in the vPortSuppressTicksAndSleep function at the line while (0 == (NVIC->ISPR[0] | NVIC->ISPR[1])) when the program moves to xSemaphoreTake(xMutex, portMAX_DELAY) in TaskTest1 function.
