Equation result is not as expected
there is an equation in the code where I see that variable: deviceid is: 229 and var_temp is also: 229.
But the debugging shows that the Mikrocontroller is going into this if-case. I cant understand why. Both variables are uint8_t and have the same value.
  • I am using Segger-Embedded-Studio V3.30.
  • I am using SEGGER EDU
  • I am using NRF52832
I have downloaded the code into Mikrocontroller several times. So I am shure that the code in the mikrocontroller is the same code as I see in the Embedded-Studio IDE.
if (deviceid != var_temp)
  ret_eok |= ERROR_BIT_0;
Do you have any ideas what is going wrong?
