I'im using nRF52840 dev kit along with S140 version 6.0.0-6.alpha. I applied the patch to SDK verison 14.0 so be able to have maximum range fr ATT MTU throughput example.
-First run of the example throws BFARVALID (Branch to an address where no code is located) hard fault error without running any code. So I loaded the linker file found in the SDK 14.2 that differ from the existing linker(SDK 14.0) in :
Linker found in SDK 14.2.0
define symbol __ICFEDIT_intvec_start__ = 0x22000;
define symbol __ICFEDIT_region_ROM_start__ = 0x22000;
define symbol __ICFEDIT_region_RAM_start__ = 0x200030d0;
Linker in SDK 14.0
define symbol __ICFEDIT_intvec_start__ = 0x25000;
define symbol __ICFEDIT_region_ROM_start__ = 0x25000;
define symbol __ICFEDIT_region_RAM_start__ = 0x200031c0;
With this new linker, the example starts normally but throws an err_code number 7 (NRF_ERROR_INVALID_PARAM)when ble_advdata_set() is called in the code. I didn't change anything in the adv data string nor the example at all.
Any idea on how I can figure out and debug this error and find a solution for it ?
NB. I was able to run and test this example from SDK version 14.2.0 which is version s140 5.0.0.alpha.
