dumping code in NRF52832
hiii friends,
i have developed new board using nRF52832 xxAA. i am dumping code in this using nrf52 DK and it is working fine but when i am removing power from this and reconnect power it is not working. but at same time if i dump simple LED program, then i am not getting this problem means after removing and reconnect power it is working fine.
now i see code is dumped correctly but every time it needs nrfgo studio to turn on the board. i.e. simply i open nrfgo studio and click on segger and my board starts.
why every time it needs this process after removing power.
what might be the problem. can any one help me with this.
  • i have given small delay in mpu section and now it is not stuck when power is on and off.
    void mpu_setup(void) {
    nrf_delay_ms(25);
    ret_code_t ret_code;
    // Initiate MPU driver
    ret_code = mpu_init();
    APP_ERROR_CHECK(ret_code); // Check for errors in return value
    // Setup and configure the MPU with intial values
    mpu_config_t p_mpu_config = MPU_DEFAULT_CONFIG(); // Load default values
    p_mpu_config.smplrt_div = 19;   // Change sampelrate. Sample Rate = Gyroscope Output Rate / (1 + SMPLRT_DIV). 19 gives a sample rate of 50Hz
    p_mpu_config.accel_config.afs_sel = AFS_2G; // Set accelerometer full scale range to 2G
    ret_code = mpu_config(&p_mpu_config); // Configure the MPU with above values
    nrf_delay_ms(25);
