experimental S120 central disconnected.reason 0x13
Hi all,
when i want to connect different peripheral on central(s120). it have a error and disconnect.
it seem ok , but that will disconnect later. ant it get disconnected .reason 0x13.
Do anybody have suggest?
[APPL]:[0x00] >> DM_EVT_LINK_SECURED [APPL]:[0x00] << DM_EVT_DEVICE_CONTEXT_LOADED [APPL]:[0x00] >> DM_EVT_CONNECTION [APPL]:[22 33 3A FD BD C8]: Connection Established
[APPL]:[CI 0x00]: Requesting GATT client create [DB]: Starting discovery of service with UUID 0x9001 for Connection handle 0 [APPL]:[0x00] << DM_EVT_CONNECTION [DB]: Discovery of service with UUID 0x9001 completed with success for Connectionhandle 0 [DB]: Starting discovery of service with UUID 0x1523 for Connection handle 0 [APPL]:[0x00] >> DM_LINK_SECURED_IND, result 0x00000000 [APPL]:[0x00] << DM_LINK_SECURED_IND
//connect another peripheral(led button service) [APPL]: connect the perihperal nordic [APPL]:[0x01] >> DM_EVT_CONNECTION [APPL]:[C7 BA BD C7 67 C4]: Connection Established
[APPL]:[CI 0x01]: Requesting GATT client create [DB]: Starting discovery of service with UUID 0x9001 for Connection handle 1 [APPL]:[0x01] << DM_EVT_CONNECTION [DB]: Starting discovery of service with UUID 0x1523 for Connection handle 1 [DB]: Discovery of service with UUID 0x1523 completed with success for Connectionhandle 1 [LBS_C]: LBS_UUID_BUTTON_CHAR discovered at peer. [LBS_C]: LBS_UUID_LED_CHAR discovered at peer. [LBS_C]: led button Service discovered at peer. [APPL]: LB Service discovered. [APPL]: Enabling button Notification. [LBS_C]: Configuring CCCD. CCCD Handle = 15, Connection Handle = 1
  • Hi steven,
    It is a bit hard to tell the reason for the disconnect as this is BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION
    It could be an event that your application does not handle, try to print out unhandled events. One could be the BLE_GAP_EVT_SEC_REQUEST or BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST. There could be other events as well, like a read or write if you have configured your local database with authorization. (Or long read, system attributes access) etc.
    BR Pål
  • Hi, Pål Håland ,
    the error message that is when i Integrate other project. and which not have device_manager_peripheral.
    the issue always Occur at one Minute when connect.
    Could you give me some information about device_manager_peripheral.
    Thank you for considering my request.
  • Just a shot in the dark: Could this be your peripheral disconnecting due to it not getting the connection parameters it wants in a connection parameters negotiation phase?
  • it seen device_manager module , which about multilink manager
