To increase the range of NRF24L01+ module using shockburst mode
I'm facing issue in the range of communication between the 2 NRF24L01+ modules(1452AB). My design is to interface the NRF24L01+ with more than 6 modules with one HUB. But for Now I'm testing only between 2 RF modules.
configuration of TX:
/*Transmission mode nRF*/
void TX_mode(void)
  /*standby-1 mode*/
  CE_LOW;
  /*Enable auto ACK data pipe 0*/
  writeRegister(WRITE_REG + EN_AA, 0x00);
  /*Enable RX addr of data pipe 0*/
  writeRegister(WRITE_REG + EN_RXADDR, 0x02);
  /*TX/RX address width is 5bytes(common for all data pipes)*/
  writeRegister(WRITE_REG + SETUP_AW, 0x03);
  /*Auto retransmit delay is 500us
   *Auto retransmit count is 10 on fail of AA*/
  writeRegister(WRITE_REG + SETUP_RETR, 0x00);
  /*Select the RF channel number
   *range of channel is 2^7 */
  writeRegister(WRITE_REG + RF_CH, 120);
  /*Data rate is 250kbps
   *Output power is 0dbm(1mW)*/
  writeRegister(WRITE_REG + RF_SETUP, 0x23);
  /*flushing TX buffer*/
  flush_TX();
/*Reception mode nRF*/
void RX_mode(void)
  /*standby-1 mode*/
  CE_LOW;
  /*Number of bytes in RX payload in data pipe 0*/
  writeRegister(WRITE_REG + RX_PW_P1, TX_PLOAD_WIDTH);
And I check TX_ds & RX_dr bits for transmission and reception status respectively.
I noticed that range of 5m to 8m its working good!! but if I try more than this range I'm losing packets.
I have attached the hardware and software detail so please help me out and guide in this.
Hardware detials:
RF.txt
