Problems with Programming nRF51822 customized board
Hi guys, me again.
I was very confused with my current process on developing with nrf chip now... so I would like to post my develop step and some problems I had so maybe you could give me some advises. I think I maybe stuck in my own circle.
I'm sorry to give such a long post here.
I have read through the tutorial about the nrf51 DK and BLE and many post about changing clock source for example. For the DK, I could successfully load the code to the DK, for example the UART transmission example and use my phone to communicate with it.
For the step for developing the DK, I first load the softdevice using command line tool, the softdevice I load to the DK is from SDK 12.2, s130, version is 2.0.1. Then I open the example in Keil, build up and then load to the DK, it was fine.
So, then I would like to try the code with my own board. First, I was using the nrf51822 module from Taiyo Yuden Inc, which the board them made doesn't have an external clock source, so I have changed the clock source to the internal RC clock source with the following code in example code in Keil5.
//set up clock source
 nrf_clock_lf_cfg_t rc_cfg =
    .source = NRF_CLOCK_LF_SRC_RC,
    .rc_ctiv = 16,
    .rc_temp_ctiv = 2,
// Initialize SoftDevice.
SOFTDEVICE_HANDLER_INIT(&rc_cfg, NULL);
For the board I'm using, please refer to the following image: image description
I connect the SWD interface to the Jlink and since the board doesn't have the reset and SWO, I only use the SWDIO and SWCLK to the Jlink. Then with the Jlink connected, I used command line tool to program the softdevice to this board. The command line tool shows the softdevice has been programmed. image description
Then I open the example in Keil5, for this time using the uart example also. I build and then load to the board. image description
After this, I open my phone and use the nordic app to scan the board, there is nothing. For my point, I was trying to see if I could program the board to be scanable and also can be connected with phone, then develop some other functionalities base on that, but I could not see the board.
Did I do anything wrong with the procedure?
That was what I have done with the Taiyo Yuden board. Since the board has all the pins under the chip, I thought maybe there is something wrong with my soldering, so I used another chip which all the pins are on the side of the board so I could see actually I have soldered them correctly. The board I'm using is this one.
For this board, I was trying some similar procedure.
I first used the nRFGo studio to program the softdevice, same version from the previous one. image description
Then I tried to load the example code from Keil, but I got an error that the Flash Downloaded fail. At first, the error says Flash Downloaded fail - could no open XXX\XXX\XXX.axf file. image description ....I was so confuse by now....
Another concern is that, if I change the device to the nrf51822_xxAA which I used with the board, the device became red and there is no update option to use for the files. image description image description
It was a long post, but I you have any idea which step I did wrong, please let me know.
Thanks
  • See below. The beacon code is pretty simple and will accomplish your need of proving your board will broadcast. It is straight from SDK 12.2 except I edited the RTC settings.
    You will have a lot to learn about programming these devices. It takes a lot of code to make bluetooth work. Beacon code is some of the simplest and the API commands for the softdevice are pretty straightforward.
    If you look in the Nordic documentation for S130 all of the API commands are explained in detail. It is a good place to start understanding how the code works.
  • Do get the binaries from AmbystomaLabs as that should give you some indication as to whether the BMD200 is really working or not. And IF you have some spare cycles left after that, how about cough out a few dollars to get the usb to ttl serial cable (eg. www.adafruit.com/.../954), attach the tx, rx and gnd to the corresponding pins in BMD200, and insert the usb end into your pc (win 7 or 8, should work with 10), install the usb driver, and viola you get a virtual COM port on your pc through which you can observe your serial debug messages (say with putty).
  • I have load the code to the BMD200 board, and if your code name device using Nordic_UART, I could scan it from my phone. Also,at early time I tried to program the board with LED, it also work.
    Ok, for now I think I get out from a confuse region where I could not make my board works. Now, I need to understand how I could make the board to do the BLE.
    Thanks for your help!
  • And Cookieeeee, that is good that you would prefer coding using the registers. I always find that easier too. You can do in one line what normally takes many lines if you use the drivers.
    Just remember that the softdevice has priority in the processor. So the exact same processor resources you use in your app code are being used by the softdevice. Because of this some register settings are considered protected and should not be written to directly. The data sheet defines these.
    Similarly ISR's from the SD have priority over your codes ISR's. Because of this don't try to do tasks that require microsecond accuracy using ISR's. There are many hardware tools like timers/counters/PPI/GPIOTE to work around these issues. You should familiarize yourself with them.
