Using SWO with nRF52 (redux)
I know this question has been asked before, but I couldn't find an answer...
I'm looking for an example of how to use the nRF52832's SWO feature with the SEGGER JLink product. I have a PCA10040 board that I can program and debug via Eclipse/GCC/Jlink. I would now like to use the SWO feature to simulate a virtual UART. (I realize that I could use the PCA10040's real UART but my eventual target doesn't have the UART so I want to use the SWO feature instead.)
I have set the following additional defines in my otherwise unchanged Nordic sample code: CFLAGS += -DENABLE_DEBUG_LOG_SUPPORT
CFLAGS += -DNRF_LOG_USES_RTT=1
CFLAGS += -DENABLE_SWO
With these settings I can single step through the initialization and write attempts to the SEGGAR functions found in the nordic SDK (external/segger_rtt/SEGGER_RTT*). This all looks fine.
I have tried to view the RTT output using JLinkGDBServer and JLinkSWOVIewer. Neither of these applications sees any output from my target.
Here is the output from JLinkGDBServer console:
SEGGER J-Link GDB Server V5.12e Command Line Version
JLinkARM.dll V5.12e (DLL compiled Apr 29 2016 15:06:43)
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: yes
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: off
Target connection timeout: 0 ms
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: nRF52832_xxAA
Target interface: SWD
Target interface speed: 4000kHz
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link OB-SAM3U128-V2-NordicSemi compiled Mar 15 2016 18:03:17
Hardware: V1.00
S/N: 682957762
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 4 bytes @ address 0x0001D2AA (Data = 0xEB0A45BB)
Reading 8 bytes @ address 0x2000FEB8
gdb> mon SWO EnableTarget 0 0 1 0
SWO enabled succesfully.
gdb> mon SWO Start 0 900000
SWO started.
--- END OF QUOTE ---
I have connected to both SWO related telnet ports (2332 and 2333) and nothing comes out. I am guessing that I am not sending the correct commands to JLink monitor for this board but I can't seem to find any documentation that describes what it should be.
Any help would be appreciated.
Jack
