PWM finish flag
If I use PWM "nrf_drv_pwm_simple_playback" and that will go to "start_playback"
How can I catch end point after it finish entire function?
BTW, the process will keep about 10 sec
Thank you!
    static nrf_pwm_values_individual_t seq0_values[]={
	nrf_pwm_sequence_t const seq0 = {
		.values.p_individual = seq0_values,
		.length = NRF_PWM_VALUES_LENGTH(seq0_values),
		.repeats = 300,
		.end_delay = 0
    nrf_drv_pwm_simple_playback(&m_pwm0, &seq0, 1, NRF_DRV_PWM_EVT_FINISHED);
edit
Frøysa Sir,
Your solution is for simple sequence, and I have to use muti pwm mode, like this
void whiteTenSec(void)
  if (m_used & USED_PWM(0))
			nrf_drv_pwm_uninit(&m_pwm0);
	printf("whiteTenSec \r\n");
	enum{
		TOP = 255,
		STEP_COUNT = 25,
		TIMES = 200
    uint32_t err_code;
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            pin12 | NRF_DRV_PWM_PIN_INVERTED, // channel 0 B
            pin13 | NRF_DRV_PWM_PIN_INVERTED, // channel 1 G
            pin14 | NRF_DRV_PWM_PIN_INVERTED, // channel 3 R
	    NRF_DRV_PWM_PIN_NOT_USED
        .irq_priority = APP_IRQ_PRIORITY_LOW,
        .base_clock   = NRF_PWM_CLK_125kHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = TOP,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
    err_code = nrf_drv_pwm_init(&m_pwm0, &config0, NULL);
    m_used |= USED_PWM(0);
		{0x80, 0x80, 0x80}
			.repeats = 5000,
			.end_delay = 0
		static nrf_pwm_values_individual_t seq1_values[]={
		{0xff, 0xff, 0xff}
		nrf_pwm_sequence_t const seq1 = {
			.values.p_individual = seq1_values,
			.length = NRF_PWM_VALUES_LENGTH(seq1_values),
			.repeats = 1,
			.end_delay = 0
		nrf_drv_pwm_complex_playback(&m_pwm0, &seq0, &seq1, 1, NRF_DRV_PWM_EVT_FINISHED);
and
void blinkyRed(void)
	enum{
		TOP = 255,
		STEP_COUNT = 255,
		TIMES = 10
    uint32_t err_code;
        .output_pins =
            pin14 | NRF_DRV_PWM_PIN_INVERTED, // channel 2 R
        .top_value    = TOP,
			{0xff,0xff,0x80},
			{0xff,0xff,0x80},
			{0xff,0xff,0x80},
			{0xff,0xff,0x80},
			{0xff,0xff,0x80}
			{0xff,0xff,0xff},
			{0xff,0xff,0xff},
			{0xff,0xff,0xff},
			{0xff,0xff,0xff},
			{0xff,0xff,0xff}
			.repeats = 50,
			.end_delay = 1
			.repeats = 50,
			.end_delay = 1
		nrf_drv_pwm_complex_playback(&m_pwm0, &seq0, &seq1, 1, NRF_DRV_PWM_FLAG_LOOP);
I want to see the situation is: white 10s -> red blink
but there is: white 1s -> redblink
Thanks again for your help...
