I am using NRF52 TWI master to read data from my sensor, I have read the twi_sensor example but it doesn't make use of nrf_drv_twi_xfer().
My question is quite straightforward, I have noticed that my settings to usenrf_drv_twi_xfer() like on Case A does not work, in that the register value written on the device is different from the one retrieved after reading the same register
Case A
int8_t twi_write_transfer(unsigned char slaveDeviceId, unsigned char reg_addr, unsigned char *txData, uint16_t bytesNumberTx)
nrf_drv_twi_xfer_desc_t twi_WriteTransferData;
twi_WriteTransferData.address = slaveDeviceId;
twi_WriteTransferData.p_primary_buf = ®_addr;
twi_WriteTransferData.primary_length = sizeof(reg_addr);
twi_WriteTransferData.p_secondary_buf = txData;
twi_WriteTransferData.secondary_length = bytesNumberTx;
twi_WriteTransferData.type = NRF_DRV_TWI_XFER_TXTX;
uint32_t flags = NRF_DRV_TWI_FLAG_NO_XFER_EVT_HANDLER;
err_code = nrf_drv_twi_xfer(&twi, &twi_WriteTransferData, flags);
return err_code;
whereas this settings does work, Case B
Case B
int8_t twi1_write_transfer(unsigned char slaveDeviceId, unsigned char reg_addr, unsigned char *txData, uint16_t bytesNumberTx) {
ret_code_t err_code;
unsigned char aux[bytesNumberTx + 1];
aux[0] = reg_addr;
memcpy(&aux[1],txData,bytesNumberTx);
twi_WriteTransferData.p_primary_buf = aux;
twi_WriteTransferData.primary_length = sizeof(reg_addr)+bytesNumberTx;
twi_WriteTransferData.p_secondary_buf = NULL;
twi_WriteTransferData.secondary_length = 0;
twi_WriteTransferData.type = NRF_DRV_TWI_XFER_TX;
return ((int8_t)err_code);
I am aware that the main difference is that on Case A more than one I2C transfer happens, however, I have check that with the first case the write into the device register failes, since reading the setting I tried to write returns the default value of that register on the device.
So, what am I setting wrong in case A?
