Difference between battery measurement on ble_app_hrs and ble_app_proximity
Hello
I am working on the NRF51DK i would like to monitor the battery percentage and notifythe value over the air to the user and aslo alert the user if the battery levels fall below the certain percentage so i started testing the battery example on the SDK where the ble_app_proximity example always showing 100percent irrespective of whatever changes have been made on the program and i tried with the ble_app_hrs example it is showing the battery value (depending upon the charge present on the cr2032battery) i dont understand why the proxmity example always showing 100percent ? and how the ble_app_hrs is working? so i request can anyone give me some brief information about this point so that i can able to understand and proceed further for my application
Thank you
  • So, looking at the examples from SDK10 and 11. The proximity example is actually using the ADC to measure the battery voltage. While the heart rate example is using a sensor simulator to update the battery value. Please look for the ble_bas_battery_level_update function.
  • yes i tried the same example as given in the ble _app_proximity and i noticed the battery _measure -interval is not getting updated based on 120seconds interval can you please describe how can i get frequent measure updates from the DK about the battey status? more importantly onethign which i didnot understand is if i power the development board via USB it is howing intially 100percent and then later it is going down to 57percent and in opposite case if i provide the power supply to the circuit via Battery CR2032 it is showing initially 100percent and after certain interval it is dropped down to 15percent i dont understand why basically VDD pin is indicating2.35 volt (Battery supply ) and 2.88volt for USB power supply but the result of the battery percent age values between these is strange results can you tell me some informations about this two points? and diode voltage drop plays a vital role in this two case?
