how to flash nRF52832 using ST-link v2 in ubuntu 16.04 ??
devzone.nordicsemi.com/.../
Using this link I'm able to build sample code in nRF52 SDK in Ubuntu.
I've customized board based on nrf52832 (Bluey Board) & ST-link v2. As per my understanding we can program nRF52832 using ST-link V2 since it is cortex-m4. But I don't know how ?
How to use nrfjprog utility along with ST-link v2 to flash nRF52832 ?
If it is not possible with nrfjprog then how to do it using openOCD (in Ubuntu 16.04) ?
Thank You !!
    nrfjprog won't work, as this is built on top of the J-Link driver and only support Segger J-Link debuggers. You can try this tutorial, which seems to describe what you are looking for.
    Jørgen
  • I've already gone through with this link...not useful....patch to openOCD is weired thing which always give some error.
  • primalcortex.wordpress.com/.../
    This link solved my own issue.
    step 1: git clone git://git.code.sf.net/p/openocd/code openocd-code
    step 2: cd openocd-code
    step 3: git pull openocd.zylin.com/openocd refs/changes/15/3215/2
    setp 4: After this we have three conflicting files that have changes that we must deal manually.
    4.1 Replace src/flash/nor/drivers.c with file on this link https://pastebin.com/5X4e9QC2
    And remove or comment line no. 49,50,54,55,105,106,110,111
    4.2 Replace src/flash/nor/Makefile.am with file on this link https://pastebin.com/WaJrKete
    4.3
    Edit tcl/target/nrf52.cfg as
    # Nordic nRF52 series: ARM Cortex-M4 @ 64 MHz
    source [find target/swj-dp.tcl]
    if { [info exists CHIPNAME] } {
            set _CHIPNAME $CHIPNAME
    } else {
            set _CHIPNAME nrf52
    # Work-area is a space in RAM used for flash programming
    # By default use 16kB
    if { [info exists WORKAREASIZE] } {
       set _WORKAREASIZE $WORKAREASIZE
    } else {
       set _WORKAREASIZE 0x4000
    if { [info exists CPUTAPID] } {
            set _CPUTAPID $CPUTAPID
    } else {
            set _CPUTAPID 0x2ba01477
    } else {
    swj_newdap $_CHIPNAME cpu -expected-id $_CPUTAPID
    set _TARGETNAME $_CHIPNAME.cpu
    target create $_TARGETNAME cortex_m -chain-position $_TARGETNAME
    adapter_khz 1000
    $_TARGETNAME configure -work-area-phys 0x20000000 -work-area-size $_WORKAREASIZE -work-area-backup 0
    flash bank $_CHIPNAME.flash nrf52 0x00000000 0 1 1 $_TARGETNAME
    flash bank $_CHIPNAME.uicr nrf52 0x10001000 0 1 1 $_TARGETNAME
    if { ![using_hla] } {
            cortex_m reset_config sysresetreq
    4.4 create empty file src/flash/nor/nrf51.c
    step 5: Edit openocd-code/src/flash/nor/nrf52.c as per primalcortex.wordpress.com/.../
    step 6:
    ./bootstrap
    ./configure
    make
    make install
    step 7: create nrf52832.cfg file & add following lines in it
    #nRF52832 Target
    source [find interface/stlink-v2.cfg]
    transport select hla_swd
    source [find target/nrf52.cfg]
    step 8: execute
    openocd -d2 -f nrf52832.cfg
    step 9: Open another terminal & execute ->
    telnet localhosta 4444
    then
    > reset
    > reset halt
    > nrf52 mass_erase
    > program demo.hex verify
    > reset
    This will load the code into nRF52832 flash.
    Hope this will help.
