Hi developer, sorry to interrupt and ask. How to use an ultrasonic sensor with nRF52? Since I search a code for nRF52 are not exist and see ultrasonic sensor can connect with nRF51. Hope that is some solution to use ultrasonic with nRF52.
Hi Khairi,
You might have some better luck if you post some specs of the sensor you are talking about. At least a part number, and maybe a link to the data sheet.
Also, what you expect to do with it.
You might find some libraries for it on mBed or some other platforms, but don't expect everything to be plug in and play.
And also if you have example working with nRF51 then you can start from there because it will typically use some SPI/I2C/UART driver from SDK which works on nRF52 as well.
Hi
If I am not mistaken, to use this sensor you have to generate a short pulse from the nRF5x, and measure the time it takes until you receive a pulse in return from the sensor?
To do that you can use the TIMER, PPI and GPIOTE peripherals in the nRF52, which allow you to generate the pulse and measure the delay without having to run a lot of code in the CPU.
The code for this could look something like this (not tested!):
#define SENSOR_PIN_OUT 2
#define SENSOR_PIN_IN 3
#define PPI_CH_A 0
#define PPI_CH_B 1
#define PPI_CH_C 2
#define GPIOTE_CH_A 0
#define GPIOTE_CH_B 1
#define PULSE_LENGTH_MS 10
#define TIMEOUT_LENGTH_MS 500
void sensor_init(void)
// Timer configuration
NRF_TIMER0->PRESCALER = 4; // (16M / (2^4)) = 1MHz timer frequency
NRF_TIMER0->CC[0] = 1;
NRF_TIMER0->CC[1] = PULSE_LENGTH_MS * 1000 + 1;
NRF_TIMER0->CC[2] = 0;
NRF_TIMER0->CC[3] = TIMEOUT_LENGTH_MS * 1000;
NRF_TIMER0->SHORTS = TIMER_SHORTS_COMPARE3_STOP_Msk | TIMER_SHORTS_COMPARE3_CLEAR_Msk;
NRF_TIMER0->INTENSET = TIMER_INTENSET_COMPARE3_Msk;
// GPIOTE configuration
NRF_GPIOTE->CONFIG[GPIOTE_CH_A] = GPIOTE_CONFIG_MODE_Task << GPIOTE_CONFIG_MODE_Pos |
SENSOR_PIN_OUT << GPIOTE_CONFIG_PSEL_Pos |
GPIOTE_CONFIG_OUTINIT_Low << GPIOTE_CONFIG_OUTINIT_Pos;
NRF_GPIOTE->CONFIG[GPIOTE_CH_B] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos |
SENSOR_PIN_IN << GPIOTE_CONFIG_PSEL_Pos |
GPIOTE_CONFIG_POLARITY_LoToHi << GPIOTE_CONFIG_POLARITY_Pos;
// PPI configuration
NRF_PPI->CH[PPI_CH_A].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[GPIOTE_CH_B];
NRF_PPI->CH[PPI_CH_A].TEP = (uint32_t)&NRF_TIMER0->TASKS_CAPTURE[2];
NRF_PPI->CHENSET = (1 << PPI_CH_A);
NRF_PPI->CH[PPI_CH_B].EEP = (uint32_t)&NRF_TIMER0->EVENTS_COMPARE[0];
NRF_PPI->CH[PPI_CH_B].TEP = (uint32_t)&NRF_GPIOTE->TASKS_SET[GPIOTE_CH_A];
NRF_PPI->CHENSET = (1 << PPI_CH_B);
NRF_PPI->CH[PPI_CH_C].EEP = (uint32_t)&NRF_TIMER0->EVENTS_COMPARE[1];
NRF_PPI->CH[PPI_CH_C].TEP = (uint32_t)&NRF_GPIOTE->TASKS_CLR[GPIOTE_CH_A];
NRF_PPI->CHENSET = (1 << PPI_CH_C);
// Interrupt configuration
NVIC_SetPriority(TIMER0_IRQn, 7);
NVIC_EnableIRQ(TIMER0_IRQn);
And then to start a reading you would simply have to start the timer:
NRF_TIMER0->TASKS_START = 1;
Best regards
Torbjørn
Can not working.
I tried using this code on GitHub by use "this link" but they are some error and warning. Since I'm beginner about nrf52 and nrf51 and connected with some device and sensor make me cannot understanding about code. Hope some can teach me.
Have you been through the nRF52 Getting Started tutorial on devzone?
You should definitely start there if you don't have previous Nordic experience. Once you have been able to complete that you can start extending the examples with more code, to read your sensor.
