Greetings, we're currently working in an application where we need to connect different peripherals to a nrf52832 for a wearable device. Each of these peripherals uses a different communication protocol, we are using the following peripherals with the respective protocol and SDK 14.1 instance:
- ADS1292R - SPI2 -Interrupt Priority 6
- MAX30101 - TWI0 - Interrupt Priority 7
- OpenLog - UART0
We've managed receive data and store it in an SD card successfully during lab conditions, but when we field test the device we are experiencing errors due to the TWI communication. If there is a situation where, for some reason, the MAX30101 is disconnected from the system the MCU will stay in an infinite loop checking for events "nrf_twim_event_check". The idea is that if for some reason this peripheral gets disconnected, and re plugged, the system would be able to recover by itself and continue its operation without the need of a complete reset. We've read various questions here in the devzone and some doubts still remain.
- Is there any way to exit this while condition?
- If we use the non-blocking characteristic could this problem be avoided? If so, what are the differences with the blocking one? How is it implemented?
- Does nrf_twim_event_check has a timeout somewhere?
Thanks beforehand for your help.
Best Regards Samuel Escobar
