How to connect nRF51822 using adxl345 SPI? needed help
Well, I have question for this SPI connection problem. anyway,I have nRF51822 core board using adxl345 with SPI connection. that connect SDA to P5, SDO to P6, SCL to P7, CS to P8. this program works fine till connect over BLE but there's no data receive from nRF UART app but there is RX event. so in my opinion, are there wrong pin or can those default SPI nRF51 pin change to using other pin? this is my mbed program
this code:
#include "mbed.h"
#include "ble/BLE.h"
#include "ble/services/UARTService.h"
#include "Serial.h"
#include "ADXL345.h"
#include "mbed.h"
#define NEED_CONSOLE_OUTPUT 1 /* Set this if you need debug messages on the console;
                           * it will have an impact on code-size and power consumption. */
#if NEED_CONSOLE_OUTPUT
#define DEBUG(...) { printf(__VA_ARGS__); }
#else
#define DEBUG(...) /* nothing */
#endif /* #if NEED_CONSOLE_OUTPUT */
ADXL345 accelerometer(p5, p6, p7, p8); // (SDA, SDO, SCL, CS);
BLEDevice  ble;
DigitalOut led1(LED1);
Serial uart1(USBTX,USBRX);
UARTService *uartServicePtr;
void disconnectionCallback(const Gap::DisconnectionCallbackParams_t *params)
    DEBUG("Disconnected!\n\r");
    DEBUG("Restarting the advertising process\n\r");
    ble.startAdvertising();
void connectionCallback(const Gap::ConnectionCallbackParams_t *params)
   DEBUG("Connected!\n\r");
 uint8_t b[40]={'a','d','q','w'};
 void onDataWritten1(const GattWriteCallbackParams *params)
    if ((uartServicePtr != NULL) && (params->handle == uartServicePtr->getTXCharacteristicHandle())) {
    uint16_t bytesRead = params->len;
    DEBUG("received %u bytes %s\n\r", bytesRead,params->data);
   // if(sFlag == 1)
   //     ble.updateCharacteristicValue(uartServicePtr->getRXCharacteristicHandle(), (const uint8_t*)b/*params->data*/, 4/*bytesRead*/);
    void periodicCallback(void)
        led1 = !led1;
int main()
uart1.baud(9600);
int readings[3] = {0, 0, 0};
uart1.printf("Starting ADXL345 test...\n");
uart1.printf("Device ID is: 0x%02x\n", accelerometer.getDevId());
//Go into standby mode to configure the device.
accelerometer.setPowerControl(0x00);
//Full resolution, +/-16g, 4mg/LSB.
accelerometer.setDataFormatControl(0x0B);
//3.2kHz data rate.
accelerometer.setDataRate(ADXL345_3200HZ);
//Measurement mode.
accelerometer.setPowerControl(0x08);
char buffer [20];
// Test Daata
memset(&buffer, 0, sizeof(buffer));
int16_t reading_1 = 54;
int16_t reading_2 = 42;
int16_t reading_3 = 32;
snprintf(buffer,20,"data: %d, %d, %d\n", reading_1, reading_2, reading_3);
led1 = 1;
uart1.baud(9600);
Ticker ticker;
ticker.attach(periodicCallback, 1);
DEBUG("Initialising the nRF51822\n\r");
ble.init();
ble.onDisconnection(disconnectionCallback);
ble.onConnection(connectionCallback);
ble.onDataWritten(onDataWritten1);
/* setup advertising */
ble.accumulateAdvertisingPayload(GapAdvertisingData::BREDR_NOT_SUPPORTED);
ble.setAdvertisingType(GapAdvertisingParams::ADV_CONNECTABLE_UNDIRECTED);
ble.accumulateAdvertisingPayload(GapAdvertisingData::SHORTENED_LOCAL_NAME,
                                 (const uint8_t *)"BLE UART", sizeof("BLE UART") - 1);
ble.accumulateAdvertisingPayload(GapAdvertisingData::COMPLETE_LIST_128BIT_SERVICE_IDS,
                                 (const uint8_t *)UARTServiceUUID_reversed, sizeof(UARTServiceUUID_reversed));
ble.setAdvertisingInterval(1000); /* 1000ms; in multiples of 0.625ms. */
UARTService uartService(ble);
uartServicePtr = &uartService;
while (1) {
    ble.waitForEvent();
    wait(0.1);
    accelerometer.getOutput(readings);
    //13-bit, sign extended values.
    uart1.printf("%i, %i, %i\n", (int16_t)readings[0], (int16_t)readings[1], (int16_t)readings[2]);
    snprintf(buffer, 20, "data: %d, %d, %d\n", (int16_t)readings[0],(int16_t)readings[1], (int16_t)readings[2]);
    ble.updateCharacteristicValue(uartServicePtr->getRXCharacteristicHandle(), (uint8_t*)buffer, sizeof(buffer), false);
