Thread cli example on nRF52840dk - USB not recognized
I try to run the thread cli example on the nRF52840dk with the SDK_for_Thread_v0.11.0_84a130f.
Windows 10 throws an error like "USB device not recognized / Error trying to get device description" (translated)
  • I tried several USB-Cable, dev kits and computers.
  • I tried it with several supply setups
  • LED5 is blinking
  • I can run the USB HID generic project, which was recognized by the computer as a device. So the usb connector / cable should be fine.
  • I installed the driver which is in the same directory /usb/thread_cli_usb_example.inf
Log output:
J-Link RTT Viewer V6.22b: Logging started.
LOG:  Global terminal added.
LOG:  Terminal 0 added.
LOG:  Device "NRF52840_XXAA" selected.
LOG:  Found SW-DP with ID 0x2BA01477
LOG:  Scanning AP map to find all available APs
LOG:  AP[2]: Stopped AP scan as end of AP map has been reached
LOG:  AP[0]: AHB-AP (IDR: 0x24770011)
LOG:  AP[1]: JTAG-AP (IDR: 0x02880000)
LOG:  Iterating through AP map to find AHB-AP to use
LOG:  AP[0]: Core found
LOG:  AP[0]: AHB-AP ROM base: 0xE00FF000
LOG:  CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
LOG:  Found Cortex-M4 r0p1, Little endian.
LOG:  FPUnit: 6 code (BP) slots and 2 literal slots
LOG:  CoreSight components:
LOG:  ROMTbl[0] @ E00FF000
LOG:  ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
LOG:  ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
LOG:  ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
LOG:  ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
LOG:  ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
LOG:  ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
LOG:  RTT Viewer connected.
Terminal Output:
0> <info> app: Thread version: OPENTHREAD/ga89eb88-dirty; NRF52840; Nov 17 2017 09:09:34
0>
0> <info> app: Network name:   OpenThread
0>
0> <info> app: State changed! Flags: 0x00001311 Current role: 0
0>
Any suggestions for further debugging / troubleshooting?
Thanks in advance!
  • OK, somehow it recognized the device and I was able to set it up and start it as thread device. But when I tried to connect to the second dev kit. I had the same error. And now that I disconnected the first one, none of them are recognized again.
  • What is the version number on your nRF52840 PDKs?
  • Here what is written on the PDKs: PCA10056, V0.9.2, 2017.32 , 683300167. In the meantime, I tried the CLI example with UART and this works for me now. So if you want me to check/test something in order to improve your firmware/hardware development, I will. Otherwise it's fine for me now.
  • There might be some issues with the nRF USB port on your board. If you want help to get the USB port to work, please create a support request on MyPage.
