When is NUS ready?
I'm using SDK 14.2 (not really relevant I guess) on an nRF52832. The application requires a greeting to be sent to the remote through NUS as soon as a connection is made. The first tranfers are always lost.
My code is as follows:
void hello_world( ble_nus_t *nus, char * str )
  uint16_t len = strlen( str );
  if ( nus->is_notification_enabled )
    ble_nus_string_send( nus, (uint8_t *)str, (uint16_t *)&len );
In main, conn_handle is defined and used to indicate a valid BLE_GAT_EVT_CONNECTED event was seen:
if ( m_conn_handle != BLE_CONN_HANDLE_INVALID )
  hello_world( &m_nus, "Hello, world\n" );
The "is_notification_enabled" field is maintained from ble_nus_on_ble_evt() in ble_nus.c, it should be reliable.
So, what is boils down to: how can I check if the remote is ready to receive data through NUS?
  • Hi
    As mentioned you can not send notifications until they are enabled by the client.
    When the notifications are enabled the service module (ble_nus.c) will alert the application to this by sending the BLE_NUS_EVT_COMM_STARTED event.
    This event is not handled by the example, but you can extend the nus_data_handler(ble_nus_evt_t * p_evt) function to handle it:
        else if(p_evt->type == BLE_NUS_EVT_COMM_STARTED)
          // Send welcome message here
    Best regards
    Torbjørn
  • That seems to do the trick, thanks!
