Cannot compile NRF51 Samples
I was compiling a project(ble_app_uart and I am using PCA10028), it was not successful and KEIL5 display this: image description it looks like I didn't install NordicSemiconductor.nRF_DeviceFamilyPack.8.11.1.pack according to the message (in fact, I already installed NordicSemiconductor.nRF_DeviceFamilyPack.8.15.0.pack). Then I downloaded NordicSemiconductor.nRF_DeviceFamilyPack.8.11.1.pack from KEIL and complied it again, it was still not successful, and KEIL5 display this: image description it looks like 8.11.1 pack is not suitable for my board? how can I fix this problem? Thanks a lot!
  • Hi Summer!
    Could you open the "Pack Installer" in Keil and verify that the Device Family Pack is installed?
    Also, on a general note;
    Your project location is causing the path to be very long. You should try to install the SDK as close to the drive base folder as possible. i.e C:/nordic/sdk_xxx. This is too avoid the max path lenght (247char) as this might cause the examples not to compile. Also try to avoid white spaces in folder names etc.
    Joakim.
  • Hi Summer!
    Joakim.
