As the tittle, how can I select frequency for radio frequency. I use nrf52 MCU.
have any example in the SDK implement change radio frequency? I don't how how to write to register .
Sure, if you simply do full-text search for that expression over whole nRF5 SDK package (typically filtered on C and H files) you will see where it is used. Because your question suggests that you have little idea about writing C code on embedded system let me warn you: this is useful only if you are writing some kind of test firmware or your own radio stack. If you intend to use some existing technology such as BLE then you never manage such low-level things from your application, this is job of lower stack.
Yep. My behavior is unusual. But I don't have any idea. I have to use nrf52840 chip to send data to many device. I want to use frequency range to implement that. Do you have any idea for me?
I run example in /nRF5_SDK_13.1.0_7ca7556\examples\peripheral\radio. They work correctly. Can I config NRF_RADIO variable in BLE example?
