SDK14: determine what modules to link/enable
Hi!
I once set up a simple project using SDK 12 and the HRS example.
Now I tried porting it to SDK 14 and SD 5. That didn't work out well.
So I started things from scratch. I now finally understand where I have to enable things, etc, but:
Where the hell do I find out what enable flags I need when? I get random linker errors that happen because I linked the right *.c file but didn't enable the module. Why do I even have to link AND enable it? How do I know which flags I have to enable when I use a certain module?
I get a heap of linker errors:
Linking target: build/firmware.out
build/firmware/main.c.o: In function `main':
/Users/yatekii/repos/230V2Switch/firmware/./src/main.c:63: undefined reference to `m_nrf_log_APP_logs_data_dynamic'
build/firmware/cble.c.o: In function `on_adv_evt':
/Users/yatekii/repos/230V2Switch/firmware/./src/cble.c:51: undefined reference to `m_nrf_log_APP_logs_data_dynamic'
build/firmware/cble.c.o: In function `delete_bonds':
/Users/yatekii/repos/230V2Switch/firmware/./src/cble.c:396: undefined reference to `m_nrf_log_APP_logs_data_dynamic'
build/firmware/cble.c.o: In function `pm_evt_handler':
/Users/yatekii/repos/230V2Switch/firmware/./src/cble.c:258: undefined reference to `m_nrf_log_APP_logs_data_dynamic'
build/firmware/gatt.c.o: In function `gatt_evt_handler':
/Users/yatekii/repos/230V2Switch/firmware/./src/gatt.c:15: undefined reference to `m_nrf_log_APP_logs_data_dynamic'
build/firmware/nrf_log_frontend.c.o: In function `nrf_log_init':
/Users/yatekii/repos/230V2Switch/firmware/./nRF5_SDK/components/libraries/experimental_log/src/nrf_log_frontend.c:171: undefined reference to `__start_log_const_data'
/Users/yatekii/repos/230V2Switch/firmware/./nRF5_SDK/components/libraries/experimental_log/src/nrf_log_frontend.c:171: undefined reference to `__stop_log_const_data'
/Users/yatekii/repos/230V2Switch/firmware/./nRF5_SDK/components/libraries/experimental_log/src/nrf_log_frontend.c:171: undefined reference to `__start_log_dynamic_data'
build/firmware/nrf_log_frontend.c.o: In function `nrf_log_frontend_dequeue':
/Users/yatekii/repos/230V2Switch/firmware/./nRF5_SDK/components/libraries/experimental_log/src/nrf_log_frontend.c:780: undefined reference to `__start_log_dynamic_data'
build/firmware/nrf_sdh.c.o:(.rodata.sdh_req_observers+0x0): undefined reference to `__start_sdh_req_observers'
build/firmware/nrf_sdh.c.o:(.rodata.sdh_req_observers+0x4): undefined reference to `__stop_sdh_req_observers'
build/firmware/nrf_sdh.c.o:(.rodata.sdh_state_observers+0x0): undefined reference to `__start_sdh_state_observers'
build/firmware/nrf_sdh.c.o:(.rodata.sdh_state_observers+0x4): undefined reference to `__stop_sdh_state_observers'
build/firmware/nrf_sdh.c.o:(.rodata.sdh_stack_observers+0x0): undefined reference to `__start_sdh_stack_observers'
build/firmware/nrf_sdh.c.o:(.rodata.sdh_stack_observers+0x4): undefined reference to `__stop_sdh_stack_observers'
collect2: error: ld returned 1 exit status
make: *** [build/firmware.out] Error 1
I traced them down to a macro:
#define NRF_SECTION_DEF(section_name, data_type)                \
    extern data_type * CONCAT_2(__start_, section_name);        \
    extern void      * CONCAT_2(__stop_,  section_name)
Which only ever marks them as extern but doesn't actually allocate any storage. Unfortunately I couldn't find the macro that actually allocates space. Where do I find it?
Also there is an entire wealth of options for the SDK which I greatly appreciate, but how in lords name do I find out which ones I need when and how? I mean it's 6k lines of text in the reference sdk_config.h ...
Thanks for any help Noah
  • Add the observers to the SECTIONS part of your linker script.
    As follows:
    SECTIONS
    .log_const_data :
    PROVIDE(__start_log_const_data = .);
    KEEP(*(.log_const_data))
    PROVIDE(__stop_log_const_data = .);
    } > FLASH
    .sdh_stack_observers :
    PROVIDE(__start_sdh_stack_observers = .);
    KEEP(*(SORT(.sdh_stack_observers*)))
    PROVIDE(__stop_sdh_stack_observers = .);
    } > FLASH
    .sdh_req_observers :
    PROVIDE(__start_sdh_req_observers = .);
    KEEP(*(SORT(.sdh_req_observers*)))
    PROVIDE(__stop_sdh_req_observers = .);
    } > FLASH
    .sdh_state_observers :
    PROVIDE(__start_sdh_state_observers = .);
    KEEP(*(SORT(.sdh_state_observers*)))
    PROVIDE(__stop_sdh_state_observers = .);
    } > FLASH
    .sdh_ble_observers :
    PROVIDE(__start_sdh_ble_observers = .);
    KEEP(*(SORT(.sdh_ble_observers*)))
    PROVIDE(__stop_sdh_ble_observers = .);
    } > FLASH
    } INSERT AFTER .text
  • It would be nice to know what conditions you need to add this to the linker script.  The linker script in the SDK components/softdevice/s132/toolchain/armgcc/<foo>.ld does not include those lines.  But another linker script I have (I can't remember where I got it) does not.  And I am getting the same linker errrors.  I would guess the answer is "if you enable observers in sdk_config.h, you need to add this text to the linker script."  But a reference to the documentation would be nice, so it is not just some magic incantation privy only to those willing to bow to the cognizetti.
  • I see that most examples have this text in their linker scripts.  But it is not clear why.  I assumed that the linker script for the s132 (path give above) would be sufficient, and maybe it is a bug in that script.  I would like to know WHY it must be there, instead of just saying "start with an example linker script instead of the s132 linker script."  I am trying to port from 52832 to 52810.  I want to start with the .ld script for the s112 instead of searching examples for one that uses s112 and then use its linker script.
