nRF52832 watchdog issue
Hi
I'm trying to implement the watchdog to my project, but I'm having some odd issues. When I power cycle the device the watchdog works fine, but when I program the device through keils Load button (system reset) the device just goes into a limbo state from which it can't recover anymore until I power cycle it, then it works fine again. I've found a similar issue in another post:
https://devzone.nordicsemi.com/question/4575/problem-with-system_reset-and-watchdog/
That post is about the nRF51, but I have the nRF52.
I found two different examples that use the wdt, one is this one:
https://github.com/NordicPlayground/nrf51-watchdog-resetreas-example/blob/master/watchdog_simple/main.c
And the other one is in keils example library that uses the nrf_drv_wdt library.
Both have the same issue.
Edit: The RESETREAS workaround has also issues sometimes.
    I am facing same issue.
    I have combine hex file of bootloader + application (SDK 14.1.0) + softdevice (S132 5.0.0).
    When I program it with nRFgo Studio, after programming, device start executing code but it hang after around 1 to 2 second. However, after power cycle, device starts working normally.
    In addition, when I remove watchdog init code from application. It is working fine even after programming. So I am suspecting issue is related to watchdog of nRF52832.
    Have you found any solution for this?
