Erasing UICR register in application code
Hello Everyone,
I am using nrf51822 with S130. After completely erasing the chip, with the below mentioned code snippet in application code:
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;
while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
*(uint32_t *)0x10001080 = hexData;
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;
I am able to write data in the UICR register. I tried subsequent writing to UICR using the same code in the application code, however, UICR data doesn't change. Based on further research I came to know that the entire chip needs to be erased for writing new data. However, I want to just erase UICR to rewrite new data to the UICR. Is there any way to erase the UICR registers in application code to rewrite new data?
Thanks
  • On the nRF51822 you cannot programatically erase the UICR. If you go to a newer variant such as the nRF52840, there is a ERASEUICR register in the NVM controller. I haven't checked the nRF52832 to see if it supports that register as well.
  • static void flash_page_erase(uint32_t * page_address) { // Turn on flash erase enable and wait until the NVMC is ready: NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
        // Erase page:
        NRF_NVMC->ERASEPAGE = (uint32_t)page_address;
            // Do nothing.
        // Turn off flash erase enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG &= ~(NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
    static void flash_word_write(uint32_t * address, uint32_t value)
        // Turn on flash write enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
        *address = value;
            // Do nothing.
        // Turn off flash write enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
    I am using above function to erase and write data to location 0x0003B000 (1 page below bootloader). But device isn't advertising. When I disable erasing, the device is advertising. Does that means I am erasing wrong location?
            // Do nothing.
        // Erase page:
            // Do nothing.
            // Do nothing.
            // Do nothing.
        *address = value;
            // Do nothing.
            // Do nothing.
