Cannot disconnect the device once it is connected
Hello guys,
I have problem, I activate the BLE and connect it to my tablet application until then nothing wrong happens. But when I use sd_ble_gap_disconnect() to disconnect, I got error_code 0x3002 which prevent me to disconnect.
what I do to disconnect:
check = softdevice_handler_isEnabled();
if (check == true && m_conn_handle != BLE_CONN_HANDLE_INVALID)
	u32_err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    APP_ERROR_CHECK(u32_err_code); //err_code returned before check 0x3002
u32_err_code = sd_ble_gap_adv_stop();
APP_ERROR_CHECK(u32_err_code);  //err_code returned before check 0x0008
I use nrf52832, s132 softdevice with uart. I want to be disconnected and stop advertising, can any one please let me know how to correct this.
Thanks in advance for your time!
PS: The device is a peripheral one
  • i tried doing it adding brackets to my statement but nothing changed. And I also tried to trace the modification of m_conn_handle but I only modify it after being disconnected
    static void on_disconnect(ble_evt_t * p_ble_evt)
        uint32_t err_code;
        // Stop timer if running
        m_update_count = 0; // Connection parameters updates should happen during every connection
        err_code = app_timer_stop(m_conn_params_timer_id);
        if ((err_code != NRF_SUCCESS) && (m_conn_params_config.error_handler != NULL))
            m_conn_params_config.error_handler(err_code);
    here is the code where it is modifed
  • Only modifying it on disconnect could also be a problem. It should be modified on connect to update it. This way, in the case you make a connection, lose it, reestablish the connect, and try to end it manually, it may no longer have the correct handle.
