Peer manager and chip/SD/SDK select
Hello, guys,
We have developed our first generation product with 51822(16KB RAM, SDK10, S110V8.0) as peripheral , and we are always facing the problem that the connection time between smart phone and our device is too long(over 2s) ,after some test ,we found the most time-costing procedure is service discovery,it tooks about 80% of the connection time(we can not afford to change the advertising interval too small since our product is battery powered, we have changed the connection interval to 20ms, and we just have two services, one is Device Information with 5 chars, another is our custom service with 4 chars), so we try to eliminate service discovery during connection according to the fact that bond will let smartphone cache service info so service discovery is only needed when bonding,which is acceptable.
We plan to add bond function to our existing project, and after some searching and reading here, we found that :(if I were wrong ,please correct me, THX)
1,Peer manager is production ready in SDK11
2,SD110 is no longer supported above SDK10
3,We have to change our chip to QFAC with 32KB RAM, since our application RAM is already about 7KB,and S130 will need at least 10KB RAM.
4,Peer manager is quite complex, integration and test may take some time.
from the cost of developing (migration of SDK and SD ,integration of Peer manager ) and chip upgrade, we are quite doubt that the choice of add bonding is right.
So ,we would like to ask:
1,Is there any other way to shorten the connection time?
2,Or if not ,we indeed have to implement Peer manager, can we shrink the peer manager function to only support JUST WORKS BONDING(this will save RAM usage and code size ,so no need to upgrade the chip)?
3,And if we can ,how to do that?
Thanks a lot.
updated:
my BLE GAP event handle code is like that :(it has been assigned by softdevice_ble_evt_handler_set())
void BSP_Ble_Periph_Event(ble_evt_t *pEvent)
static U32 timer;   // 超时断开计时器
    ble_gatts_evt_write_t *pWrite;
    T_EventArgs e;
    // 检查事件对象
    if (pEvent->evt.gap_evt.conn_handle != s_tThisData.ConnHandle) {
        if ((pEvent->header.evt_id) != BLE_GAP_EVT_CONNECTED) {
            return;
    // 处理事件
    switch (pEvent->header.evt_id) {
        // 连接
        case BLE_GAP_EVT_CONNECTED: {
            Debug(__INFO__, "Connected [%02X:%02X:%02X:%02X:%02X:%02X]",
                  pEvent->evt.gap_evt.params.connected.peer_addr.addr[5],
                  pEvent->evt.gap_evt.params.connected.peer_addr.addr[4],
                  pEvent->evt.gap_evt.params.connected.peer_addr.addr[3],
                  pEvent->evt.gap_evt.params.connected.peer_addr.addr[2],
                  pEvent->evt.gap_evt.params.connected.peer_addr.addr[1],
                  pEvent->evt.gap_evt.params.connected.peer_addr.addr[0]);
            s_tThisData.ConnHandle = pEvent->evt.gap_evt.conn_handle;
            s_tThisData.ConnParams  = pEvent->evt.gap_evt.params.connected.conn_params;
            e.Type = EventType_Connect;
            e.Status = EventStatus_Seccess;
            BSP_Ble_Periph_EventCallBack(&e);
            Delay.Start(&timer);
        } break;
        // 断开
        case BLE_GAP_EVT_DISCONNECTED: {
            Debug(__INFO__, "Disconnected");
            s_tThisData.ConnHandle = BLE_CONN_HANDLE_INVALID;
            s_tThisData.AdvData.Data[27] = False;   // 关闭连接请求
            _AdvertisingStart();
            e.Type = EventType_Disconnect;
        } break;
        // 接收数据
        case BLE_GATTS_EVT_WRITE: {
            pWrite = &pEvent->evt.gatts_evt.params.write;
            T_Char *pChar = _GetChar(pWrite->handle, 0);
            if (pChar != Null) {
                if (pWrite->handle == pChar->Handles.value_handle) {
                    s_tThisData.ReadBuff.Len = pWrite->len;
                    memcpy(s_tThisData.ReadBuff.Data, pWrite->data, s_tThisData.ReadBuff.Len);
                    e.Type = EventType_Recived;
                    e.Value = pChar->UUID.uuid;
                    e.Data.Len = s_tThisData.ReadBuff.Len;
                    e.Data.p = s_tThisData.ReadBuff.Data;
                else if (pWrite->handle == pChar->Handles.cccd_handle) {
                    if (pWrite->len == 2) {
                        if (pWrite->data[0] == BLE_GATT_HVX_NOTIFICATION) {
                            pChar->NotificationFlag = True;
                        else {
                            pChar->NotificationFlag = False;
        } break;
        // 广播超时
        case BLE_GAP_EVT_TIMEOUT: {
        } break;
        // 连接参数更新
        case BLE_GAP_EVT_CONN_PARAM_UPDATE: {
			Debug(__INFO__,"PARAM_UPDATE");
            s_tThisData.ConnParams = pEvent->evt.gap_evt.params.conn_param_update.conn_params;
            sd_ble_gap_conn_param_update(s_tThisData.ConnHandle, &s_tThisData.ConnParams);
			Debug(__INFO__,"min int %d max int %d slave lat %d timout %d",
				s_tThisData.ConnParams.min_conn_interval,
    			s_tThisData.ConnParams.max_conn_interval,
    			s_tThisData.ConnParams.slave_latency,
    			s_tThisData.ConnParams.conn_sup_timeout);
            if (Delay.Check(&timer, 180000)) {
				Debug(__INFO__,"Connection Timeout!");
                BSP_Ble_Periph_Disconnect();
        } break;
        case BLE_GAP_EVT_SEC_PARAMS_REQUEST: {
            Debug(__INFO__, "BLE_GAP_EVT_SEC_PARAMS_REQUEST");
            sd_ble_gap_sec_params_reply(s_tThisData.ConnHandle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        } break;
        case BLE_GATTS_EVT_SYS_ATTR_MISSING: {
            Debug(__INFO__, "BLE_GATTS_EVT_SYS_ATTR_MISSING");
            sd_ble_gatts_sys_attr_set(s_tThisData.ConnHandle, NULL, 0, 0);
        } break;
and the print from 51822 when SAMSUNG S7 connecting is like that: image description
It seems the smart phone try to update the connection parameter with conn int 6**(unit is supposed to be 1.25ms)** lots of times ,and finally it have to change the connection interval to 39.
the print from 51822 when OPPO R11 connecting is like that:image description
The param update finished very quickly,and they finally agree to 9.
I am not sure it is the 51822 rejecting the 6 conn int, but I want to know why two different phone act differently,and why 6 connection interval can not be achieved.
Thanks a lot, if you need more information, please let me know.
UPDATED AGAIN:
after remove sd_ble_gap_conn_param_update() at BLE_GAP_EVT_CONN_PARAM_UPDATE, the param update procedure for two different android phones both reduce to twice,and the parameter finally get to 36 or 39, although the phone try to set 6.
the print for SAMSUNG S7 is like that: image description
and the print for OPPO R11 is like that: image description
And I check the time of DFU, two phones are almost the same(R11 was much faster than S7 before).
Can I say it all depends on phone to decide the connection parameter? why can not be set to 6?
If I want to initialize the param update from peripheral, Where should I call sd_ble_gap_conn_param_update()? how to achieve the 7.5ms connection interval(it seems both phones supports 7.5ms)?
  • I don't know why your DFU procedure goes faster. It could make sense to call it once, but not every time you get BLE_GAP_EVT_CONN_PARAM_UPDATE the event.
    You don't have to set the connection parameters in the peripheral, if you get BLE_GAP_EVT_CONN_PARAM_UPDATE they are already set.
    Why would you call sd_ble_gap_ppcp_set()? That would just set Set GAP Peripheral Preferred Connection Parameters.
