Hi In our Nordic SDK ble_peripheral projects , It almost support following boards
1. pca10028
2. pca10036
3. pca10040 .
I want to port in pca20006
May I know the way ?
1. pca10028
2. pca10036
3. pca10040 .
Use the pca10028 project.
If you are using Keil, then under "Options for target" -> "C/C++" tab, under "Preprocessor Symbols" remove the define BOARD_PCA10028, and add the define BOARD_PCA20006.
If you are using GCC, you need to modify the makefile. Change ASMFLAGS += -DBOARD_PCA10028 to ASMFLAGS += -DBOARD_PCA20006
You also might need to adjust the FLASH/RAM settings, depending on what version of the PCA20006 you have.
Make sure that you have flashed the SoftDevice.
Also make sure that you have changed from external LF crystal to internal RC oscillator. See this post: devzone.nordicsemi.com/.../
If its still not working, try debugging. See this post: devzone.nordicsemi.com/.../
