nRF240L01 with STM8L051F3
Hi, I am looking for procedure to make it work nRF240L01? I am getting documents for Arduino but as you know that is not understandable, with Arduino it worked but i don't understood. Now i want to make it work with STM8L051F3. STM8L051F3 is 8 bit ultra low power controller. I am looking for procedure like what steps i have to follow so i can send data to another nRF240L01. Which commands i have to send. I want to transmit data after every 1 sec and then it will go in power down. Receiver will be always in receiver mode.
  • I was working on other matters for a week and now comeback with NRF24L01+
    Thank you for your suggestions. In one case I can use a processor with 3,6V so no level problem
    In other case, with 5V supply, MOSI, CLK, CE, CSN are input with no clipping and tolerating 5V
    MISO seems to be open drain and with 4K7 resistor to+5V is OK for procesor SPI data input.
    A similar resistor at IRQ has not any usefull level correction, but I wil place an small mosfet (2N7002)
    and 4k7 drain to +5V resistor as inverter.  Procesor interrupt input to be set as active for low to high transition
    I am writing a new assembler following your mentioned steps.
    After a carefull revision of soft and hardware,  I will test and inform you about it
    Regards, Osvaldo
  • Hi Osvaldo
    You mean the nRF24L01+ appears to work fine even if you apply 5V on the signal lines?
    I would strongly discourage this if you are planning to go to production with this project. Using the part outside the specified operating range means you could have unpredictable issues down the line, and there is a higher risk that devices will stop working in the field even if they might work on your desk.
    Sounds like a plan. Good luck Slight smile
    Best regards
    Torbjørn
  • -- PTX -- 1) Set the PWR_UP bit in the CONFIG register 2) Set DYNPD to 0x3F 3) Set the EN_DPL bit in the FEATURE register 4) Upload a payload 5) Pulse CE for 10 us 6) Add a delay (1ms+) and repeat from 4) --PRX-- 1) Set the PWR_UP and PRIM_RX bits in the CONFIG register 2) Set DYNPD = 0x3F 3) Set the EN_DPL bit in the FEATURE register 4) Set CE high 5) Wait for the IRQ line to go low 6) Read out the RX payload 7) Repeat from 5)
    Dear Torbjørn,
    I just found this while seeking an answer to my own problem. I am programming  in C using an NXP FRDM-K64F dev kit which provides a handy socket just made for common modules using your chip.I have succeeded in getting TX to work and can see my packets going out on a sniffer, but never can get an RX packet to pull IRQ.  I just went through your notes and am doing exactly the same, except I am not setting up DPL. Should it still work or is DPL mandatory?
    DPL is strictly not required, but you will need to have the same configuration on both PRX and PTX device.
    So if one side is using static payload and the other is using dynamic payload; there will be mismatch.
    Have you checked that bits 4:6 in CONFIG register is set to '0'?
    If the nRF24L-series radio has its FIFO registers already filled up, it will stop reflecting IRQ - you can check the FIFO_STATUS to see if this has occurred.
    Håkon
  • God ettermiddag kjære Håkon,
    (that's the limit of my Norwegian! :-) )
    I set bits 4:6 in control at start of program, but clear them when I go to receive mode by writing 0x03 to the register.
    I did get one packet received on the weekend (noticed by hitting a breakpoint in my handler code) after I added CRC to my TX, but it seems that it may have been caused by RX of a local thermostat!  Since then I cannot receive packets I am sending, but my sniffer tells me they are going out.
    I have DPL disabled and am sending fixed length 32-byte packets.
    All three MCUs have exactly the same code.
    Not sure it can be a buffer full problem since is observed from reset, but will now write some code to check that.
    I should mention that my target app is an audio store-and-forward radio relay system that does not need most of the protocol you have built in to your chip - as it is basically a UDP network if I can steal a term from 802.03.
    I have another question: I see you have a chip for 900 MHz ISM band, are you aware of any manufacturer that makes boards to evaluate it?  It is a commonly-used band here in Canada for ISM as well as amateurs, and my spectrum analyser only goes to 999 MHz so it would help me debug!
    Tusen takk for your help.
    God tag,
    Nigel
