I'm developing a server model and a client model(Both example are modified in accordance with the example of light_switch). In the example of client, I use the API "simple_on_off_client_set" to send a command with 16 bytes to server. The server is able to receive the 16 bytes data. However, the data received from client is wrong occasionally.
Client model:
It sends a command with 16 bytes(03006E68732E686363092E74772F0000)
Server model:
Condition 1, It receives different contents which length is 16 bytes as below
1.03006E68732E686363092E74772F0000(Correct)
2.00000000732E686363092E74772F0000(Incorrect, occasionally)
Condition 2, In case of the parameter of BEARER_SCAN_WINDOW_DEFAULT_MS is set to less than BEARER_SCAN_INT_DEFAULT_MS, it will receive a wrong message frequently .
3.B50EEB9125A84FCFCDA0ECA68A6EB700(Incorrect, occasionally)
4.54B4B7EB732E686363092E74772F0000(Incorrect, occasionally)
I got some questions about both conditions.
In the condition 1
-a.How does incorrect data occurred?
-b.Why does incorrect data can get the same length as correct one?
-c.Except the first four bytes, the others are identical. Why?
In the condition 2
-a.In case that the BEARER_SCAN_WINDOW_DEFAULT_MS is set to less than BEARER_SCAN_INT_DEFAULT_MS, why does the server is able to receive the same length?
