SDK for Mesh v1.0.0 with SES "invalid ASCII encoded byte:line 1"
I am trying to build and debug the Mesh v1.0.0 light-switch server example and getting a cryptic error when launching the debug.
My environment is Segger v3.30 on macOS. I picked up the SES .emProject and flash_placement.xml files from the examples/light_switch/server directory, but had to make several changes to the .emProject file.
When building I get a warning "cannot find entry symbol Reset_handler: defaulting to ..." but the build completes. When I thereafter initiate Debug>Go, the Output view shows "Preparing target for download" is completed and then there is a Segger GUI popup "invalid ASCII encoded byte:line 1"
Any suggestions on how to proceed would be welcome.
The top of my .emProject file shows the value of the 'linker_section_placement_macros', where the values were picked up from the .ld file in ..examples/light_switch/server/linker/nrf52832_xxAA_s132_5.0.0.ld
<!DOCTYPE CrossStudio_Project_File> <solution   Name="light_switch_server_nrf52832_xxAA_s132_5.0.0" target="8"   version="2">   <project Name="light_switch_server_nrf52832_xxAA_s132_5.0.0">
    <configuration
      Name="Common"
      arm_architecture="v7EM"
      arm_core_type="Cortex-M4"
      arm_endian="Little"
      arm_fp_abi="Hard"
      arm_fpu_type="FPv4-SP-D16"
      arm_linker_heap_size="1024"
      arm_linker_process_stack_size="0"
      arm_linker_stack_size="2048"
      arm_linker_treat_warnings_as_errors="No"
      arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
      arm_target_device_name="nrf52832_xxAA"
      arm_target_interface_type="SWD"
      c_preprocessor_definitions="NO_VTOR_CONFIG;NRF52;NRF52_SERIES;NRF52832;NRF52832_XXAA;S132;SOFTDEVICE_PRESENT;SD_BLE_API_VERSION=5;NRF_SD_BLE_API_VERSION=5;BOARD_PCA10040;CONFIG_GPIO_AS_PINRESET"
      c_user_include_directories="include;../include;../..;../../common/include;../../../external/nRF5_SDK_14.2.0_17b948a/components/drivers_nrf/delay;../../../models/simple_on_off/include;../../../models/config/include;../../../models/health/include;../../../mesh/access/api;../../../mesh/access/include;../../../mesh/prov/api;../../../mesh/prov/include;../../../external/nRF5_SDK_14.2.0_17b948a/components/boards;../../../external/nRF5_SDK_14.2.0_17b948a/components/drivers_nrf/hal;../../../external/nRF5_SDK_14.2.0_17b948a/components/libraries/util;../../../external/softdevice/s132_5.0.0/s132_nrf52_5.0.0_API/include;../../../external/softdevice/s132_5.0.0/s132_nrf52_5.0.0_API/include/nrf52;../../../mesh/core/api;../../../external/nRF5_SDK_14.2.0_17b948a/components/device;../../../external/nRF5_SDK_14.2.0_17b948a/components/toolchain;../../../external/nRF5_SDK_14.2.0_17b948a/components/toolchain/cmsis/include;../../../external/nRF5_SDK_14.2.0_17b948a/components/toolchain/gcc;../../../external/nRF5_SDK_14.2.0_17b948a/components/toolchain/dsp/GCC;../../../external/rtt/include;../../../mesh/core/include;../../../mesh/dfu/api;../../../mesh/dfu/include;../../../mesh/prov/api;../../../mesh/prov/include;../../../mesh/bearer/api;../../../mesh/bearer/include;../../../external/micro-ecc;../../../mesh/core/include;"
      debug_additional_load_file="$(ProjectDir)/../../../external/softdevice/s132_5.0.0/s132_nrf52_5.0.0_softdevice.hex"
      debug_start_from_entry_point_symbol="No"
      debug_target_connection="J-Link"
      linker_output_format="hex"
      linker_printf_width_precision_supported="No"
      linker_section_placement_file=""
      linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_START=0x23000;FLASH_SIZE=0x55000;FLASH_PH_SIZE=0x80000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x10000;RAM_START=0x200031b0;RAM_SIZE=0xcb50"
      linker_section_placements_segments="FLASH RX 0x00000000 0x78000;RAM RWX 0x20000000 0xf000"
      project_directory=""
      project_type="Executable" />
    <folder Name="Application">
      <file file_name="src/main.c" />
      <file file_name="../../nrf_mesh_sdk.c" />
  • Mesh SDK and NRF5 SDK are not related. The guide to move mesh into the nRF5 SDK is only needed if you want to use the NRF5 SDK libraries or want to add mesh into your normal nRF5 SDK application.
    Mesh SDK is a stand alone SDK and it's has been tested thoroughly before released. The SES example should work out of the box. There should be something wrong here.
    I'm not 100% sure why these sections are included in the .ld file, but most likely they are not currently used in the Mesh application. If you have a look at the .ld file in the same folder but in the last SDK v0.10.1 you can find that it's pretty simple.
    Could you check if in the Output folder if you have the hex file ? Please try to use CMake and compile the example also. In my case here (and we haven't seen any report from other customer) , the example compiled out of the box (on a Windows 7 machine).
